302 conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2009, 09:02 PM   #1
DeerHuntin9124
Blue on Black
DeerHuntin9124's Avatar
Default 302 conversion
I have a 1986 Bronco 2 currently with a 2.9 6 cylinder. I am planning on converting it to a 302 with a c4 transmission. My question is the transmission is out of an old ass LTD 2 and its only two wheel drive. Would I have to find a different transmission or just find a transfer case for a C4. Appreciate some advice
DeerHuntin9124 is offline   Reply With Quote
Old February 4th, 2009, 09:33 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
The only transfer case offered from the factory is the Early bronco 20, good case but getting expensive. There are aftermarket adapters to other transfer cases but they are money also.
If you want to be cheap a Sbf C6 would be your best option or a AOD
Old February 5th, 2009, 09:52 AM   #3
Dirt_Devil
Dirt_Devil's Avatar
Dana 20 maybe you are thinking early Bronco...
He should be able to use the C4 with the BW1350 that is in the BII. You can find a lot more useful information at therangerstation.com tech page.
Dirt_Devil is offline   Reply With Quote
Page generated in 0.15541 seconds with 32 queries
