Battery ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2009, 05:36 PM   #1
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Default Battery ?
School me on Batteries.
My WONDERFULL WIFE good grief! has left her lights on when she went into work 2 times in the past 2 weeks.
She just tried to jump it and it wouldn't start so she's chilling with a friend till I get off work to try to get it started.
I've heard that after you drain a battery a couple of times it goes bad and that in the winter your pretty much assured that you'll be buying a new one if you drain it.
So . . . am I going to be purchasing a new battery in about an hour?
Thanks!
Old February 3rd, 2009, 05:51 PM   #2
jeepguy74
jeepguy74's Avatar
i would say yes.....
Old February 3rd, 2009, 06:06 PM   #3
xj97sport
atv rider
xj97sport's Avatar
brake out the hydrometer and check the cells
Old February 3rd, 2009, 06:52 PM   #4
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
x2.
I had mine load tested at Autozone and it passed. Then I had it tested with the hydrometer and found that I had a bad cell.
Mine went bad from a bad electrical connection that drained it a bunch of times.
Old February 3rd, 2009, 07:04 PM   #5
xjmichigan
xjmichigan's Avatar
pony up, especially if it is over 5 years old.
Old February 3rd, 2009, 08:04 PM   #6
chris1044
chris1044's Avatar
Thanks!
Draining a battery harms it when a) the internal chemistry goes bad (read: check with hydrometer) and b) when you charge it at a fast rate - this goes for anytime you charge a battery for the most part (dependent upon type): slower is better. If you charge at a high current rate (fast charge) you run the risk of overheating the internal plates which can cause the cell to go bad......
I'd suggest getting the battery load tested. If it fails, attempt to charge it for a few hours at like a 6-10 amp charge rate. Retest, and if it fails again it's bad.....I suggest doing this a) because it's the right way to check a battery and b) if you do have a bad battery, you can fry your alternator costing you even more $$
Old February 3rd, 2009, 08:35 PM   #7
Chiefwoohaw
Well I just bought an optima.
Old February 3rd, 2009, 09:03 PM   #8
chris1044
chris1044's Avatar
to be safe, I'd have the alternator output tested....BUT, if you have someone do this (think autozone does it on the vehicle for free), make sure that if they want to load test the battery, they DO NOT use a carbon pile type loading device - they'll ruin glass mat type batteries (Optima's).....
Old February 3rd, 2009, 10:07 PM   #9
CaptainBadAZZ
A.K.A. The Impact
CaptainBadAZZ's Avatar
Be glad she's not running a diesel.
CaptainBadAZZ is offline   Reply With Quote
Old February 3rd, 2009, 11:08 PM   #10
Chiefwoohaw
I replaced those TWO batts earlier this year
Old February 3rd, 2009, 11:12 PM   #11
wingman573
Here and gone
wingman573's Avatar
my yellow top optima just died on me a few days ago and I've only had it for two years
wingman573 is offline   Reply With Quote
Old February 4th, 2009, 01:11 PM   #12
Chiefwoohaw
Take it back.
Page generated in 0.40510 seconds with 59 queries
