97 F-150 4WD not working - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 2nd, 2009, 12:37 PM   #1
Chrisholmz
ESTRADA
Chrisholmz's Avatar
Send a message via Yahoo to Chrisholmz
Default 97 F-150 4WD not working
My question is do vacuum servo's on front axle assemblies go bad? I've never seen one actually quit working. The t-case engages and the vacuum lines at the servo are reading 15 hg's. When I engage the axle by pushing the servo over manually the 4WD engages and works fine. It will work until I shift the truck back into 2WD and the servo will disengage the axle. Put it back into 4WD and i'm back to crawling under the truck again. Will the part fail again, or should I consider getting a cable set up?
Chrisholmz is offline   Reply With Quote
Old February 3rd, 2009, 09:23 PM   #2
Chrisholmz
ESTRADA
Chrisholmz's Avatar
not everyone at once, please!!
Old February 22nd, 2009, 09:40 PM   #3
Chrisholmz
ESTRADA
Chrisholmz's Avatar
Well, I hate doing searches and finding threads that do not have any answers or ideas so I figured I should post an update.
Vacuum servos can go bad. It also appears they can get stuck as well. I soaked the linkage points thoroughly with WD40 and manually kept working the servo in and out. Now, it does engage and disengage. I expect the part to fail in the near future but this little trick should get me out of winter.
Old February 22nd, 2009, 10:40 PM   #4
oz97tj
Wasn't this attached?
oz97tj's Avatar
I had a 97 years ago. I had it fixed at a shop, but if I remember right I think the little finger deal that engages the front axle is what broke. I remember the guy telling me it was fairly common.
I don't know if this helps.
Also, it wasn't really expensive to have it fixed. $100 ish
********GLFWDA.org********
Old February 23rd, 2009, 09:17 PM   #5
Chrisholmz
ESTRADA
Chrisholmz's Avatar
I know the part your talking about, it is fine. Something in the vacuum servo was causing the shaft to not pull in when the vacuum motor would try to suck it in. The truck isn't worth putting too much money in but it doesn't have high mileage so I want to get more use out of it before I get rid of it.
Page generated in 0.21967 seconds with 38 queries
