4.0 4.2 head swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech > Jeep tech FAQ
Jeep tech FAQ Look here first!
Old February 1st, 2009, 03:17 PM   #1
charlietaft
charlietaft's Avatar
Default 4.0 4.2 head swap
I wastold that it is posible to put a 4.0 head on a 4.2. IS THIS TRUE? And if so what is needed to do so? Is there any power gain or loss? Would i just be better off to just put in a 4.0? I am new to the jeep thing and am realy trying to understand. Thanks for any help /information you can give me.
charlietaft is offline   Reply With Quote
Old February 1st, 2009, 03:21 PM   #2
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
use to be a write up on cjoffroad, but the site is down right now. def gives more power
Old February 1st, 2009, 03:47 PM   #3
jakesjeep01
Fukc it
jakesjeep01's Avatar
try this,
http://www.monsterslayer.com/pages/j...ead/40Head.htm
jakesjeep01 is offline   Reply With Quote
Old February 1st, 2009, 07:00 PM   #4
stinkpickle
bitter clinger
stinkpickle's Avatar
has to be a head off a mid 90s or newer. cant remember exact year but the newer ones provide better air and exhaust flow. check out Clifford thats where I got my info from, they are good with i6s and they have lots of performance parts.
stinkpickle is offline   Reply With Quote
Old February 1st, 2009, 11:46 PM   #5
jeepxj2007
Send a message via AIM to jeepxj2007
on jeepforum.com I was told it would give you up to 50 horsepower...I was considering it, I am guessing you would need the head, intake manifold, computer from a 4.0, fuel pump in the tank...and probably a few other things I am forgetting, but yes it will bolt up, you need to plug a few of the water jackets in the 4.0 head iirc.... if you go to jeepforum.com and go to the yj forums and search there is a lot of discussion about it usually and you should be able to find what you need if you didn't from the link above.
jeepxj2007 is offline   Reply With Quote
Old February 2nd, 2009, 02:21 PM   #6
charlietaft
Thanks for all the great info. Now all I need is the time to do it
Old February 3rd, 2009, 09:38 AM   #7
PavementPounder
PavementPounder's Avatar
Yes. Just use the entire motor. If you have a 4.0 and a 258 at your disposal, you can assemble a stroker. Google.
People on JF don't explain things very well and have serious misconceptions about certain "popular" CJ mods, as well. The power gain they are describing is to use the entire FI system on the 258, which is only worth it if you know that your 258 has a lot of life ahead of it.
Old February 3rd, 2009, 05:31 PM   #8
charlietaft
I have a 4.2 in my 88 YJ with less than 60 thousand on it . I'm hopeing it is gonna have some good life in it yet. I am just looking for better performance and more power , and I have access to a rebuilt head and all the fuel injection stuff off a 4.0 So I was just looking for the cheapest way to do it . THANKS AGAIN FOR ALL THE ADVISE!!
Old February 3rd, 2009, 06:37 PM   #9
Trail Junkie
iamfawkinwithyou
I did HEI dist, Howel FI and a Header on my 4.3 and it performs great, might be a better route for ya
Old January 25th, 2010, 06:40 PM   #10
J Truck Rick
J Truck Rick's Avatar
You can keep it carbed,use the aluminum 2 bbl manifold& mc 2100 or weber.....you do need to use the 4.0 exhaust manifold.The 258 has a longer stroke than the 4.0,so it makes more torque than the 4.0.
J Truck Rick is offline   Reply With Quote
Page generated in 0.44818 seconds with 53 queries
