97 f250 7.3 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2009, 02:33 PM   #1
m123mann
Default 97 f250 7.3 help
OK Guys My 97 f 250 7.3 turbo deisel Needs you help
I was driving home the other day & the + cable pulled out of terminal on #1 batt every thing shut down I reconected & it started right up I took off & now my speedo does not work the O/D switch says off & is blinking & trans shifts at all differnt times & shifts so hard feels like it's going to rip out the drive line So what do I look for?
m123mann is offline   Reply With Quote
Old January 31st, 2009, 04:15 PM   #2
masterbeatty
masterbeatty's Avatar
it sounds to me like the vss is bad. or it has a trans problem. the od light blinking is showing a trans problem. but the vss will cause it to shift hard, random and the spedo wont work right. had to change a few on my bronco. id try and pull codes, also maby try and reset the computer. but it will be trans or vss
Page generated in 0.18788 seconds with 29 queries
