Polaris Trailblazer 250/ Shuts down ??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2009, 12:33 PM   #1
slvrlake survivor
It Aint Cheap to Jeep.
slvrlake survivor's Avatar
Default Polaris Trailblazer 250/ Shuts down ???
will start up and run just fine for about 20 minutes, but after a while it starts bogging down and eventually stalls out and wont restart untill its sat for quite a while. Any ideas whats causing this problem? Carb?
slvrlake survivor is offline   Reply With Quote
Old January 30th, 2009, 12:39 PM   #2
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Send a message via AIM to dakotaguy1
do you ride it alot? or does it sit for long periods of time between riding
dakotaguy1 is offline   Reply With Quote
Old February 2nd, 2009, 02:47 PM   #3
bigblue2230
still goin
bigblue2230's Avatar
Gas tank not venting properly? Can create a low pressure in the tank, and not allow fuel to flow out the bottom to the carb. After time it might allow enough air into the tank to allow the engine to restart.
bigblue2230 is offline   Reply With Quote
Old February 2nd, 2009, 05:15 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
x2 try running it with the cap off
Old February 3rd, 2009, 07:31 PM   #5
slvrlake survivor
lately its been sitting for long periods of time without riding
Old February 3rd, 2009, 07:33 PM   #6
slvrlake survivor
hadn't thought of the gas tank not venting properly. but thats a good idea, i'll have to give that a try. Thanks!
Old February 3rd, 2009, 07:40 PM   #7
KTM Mike
While you are at it - put in a new spark plug and clean or replace the air filter. Plug because good chance it may of been fouled with this crappy running going on. Air filter - well seems many people seem to forget about that! and, if it has been setting for a while some mice etc. might of gotten in there and plugged things up. (which would contribute to a fouled plug) . AND....dont forget - some fresh gas in the tank - has the gas been in there a long time and went bad? Failing all that - yank the carb, grab some carb cleaner and spray the crap outt every orfice in it.
KTM Mike is offline   Reply With Quote
Page generated in 0.24583 seconds with 44 queries
