sj413 roll-over ??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2009, 04:55 AM   #1
toghoj86
zuk sj416 supercharged
Default sj413 roll-over ???
finally i got my zuk 413 & swaped 4agze ( 210nm of torque & 165hp ) , and i decide to put toyota hilux ( truck ) axles ( 8" ) , but here in jordan . the prices is so high ( 800 $ for both axles ) ... i don't have the much of money for the axles . so im going to put 15"x10" on the zuk axles with 32"/33"x..x15" tires .
the question is : would it be easy to roll-over on the zuk's axles with 10" width wheels and that tires ????
toghoj86 is offline   Reply With Quote
Old January 30th, 2009, 05:10 AM   #2
VonDirt
VonDirt's Avatar
theres alot of "what ifs" in your question - lift, center of gravity, back spacing, etc. all play a part in how tippy a rig gets. wider and lower is better in general, but theres alot of unknown factors -
you might want to move your post to general tech.
VonDirt is offline   Reply With Quote
Old January 30th, 2009, 06:08 PM   #3
scottie
Eye candy
scottie's Avatar
How big of a lift are you running.
I would think you are probably running around 6-8 inches of lift. I'd suspect that it would be rather Tippy, but not that bad. Probably have to drive it lightly, which would ruin the fun, especially with the extra power you have
scottie is online now   Reply With Quote
Old February 2nd, 2009, 09:39 AM   #4
jeepman784
Now pedals a bicycle
jeepman784's Avatar
Send a message via AIM to jeepman784
get some spacers for your axles 2" on each side. that'll make you plenty wide with the 15x10's if you are going with 2-3" backspacing. If you want more unsurung weight as well, you can just add a buncha trussing :)
jeepman784 is offline   Reply With Quote
Page generated in 0.23996 seconds with 35 queries
