Tracker wont start but will with starter fluid? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 28th, 2009, 10:27 PM   #1
Jb1986
Bowtie boy
Jb1986's Avatar
Default Tracker wont start but will with starter fluid?
I have a 94 tracker and i wont start unless i spray starter fluid into the intake then it runs great wut the hell could it be and if u had the same problem tell me how u resolved it!!
Jb1986 is offline   Reply With Quote
Old January 28th, 2009, 10:30 PM   #2
CaptainBadAZZ
A.K.A. The Impact
CaptainBadAZZ's Avatar
Check ur fuel pressure. If good your regulator is bad.
CaptainBadAZZ is offline   Reply With Quote
Old January 28th, 2009, 11:02 PM   #3
Jb1986
Bowtie boy
Jb1986's Avatar
the regulator could kause that not to start but run like a champ after i spray starter fluid in there
Old January 28th, 2009, 11:17 PM   #4
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
want to trade you tracker for a drag car?
Old January 28th, 2009, 11:25 PM   #5
Jb1986
Bowtie boy
Jb1986's Avatar
sure do
Old January 28th, 2009, 11:30 PM   #6
chadcooper55
sorry, couldnt help myself!
Old January 28th, 2009, 11:31 PM   #7
CaptainBadAZZ
A.K.A. The Impact
Default hmmm...
Dumb question but is your fuel pressure above normal or at/below normal operating?
Old January 28th, 2009, 11:31 PM   #8
Jb1986
Bowtie boy
Jb1986's Avatar
ya do u got any ideas or just being a smartass
Old January 28th, 2009, 11:33 PM   #9
Jb1986
Bowtie boy
Jb1986's Avatar
itz at normal pressure it just wont purge into the body to get it to start i have to do that for some reason
Old January 28th, 2009, 11:54 PM   #10
CaptainBadAZZ
A.K.A. The Impact
Check your injector resistance, it should be 1.0-2.0 ohms. Is this a cold start issue due to mother nature being a cold whore?
Old January 28th, 2009, 11:59 PM   #11
Jb1986
Bowtie boy
Jb1986's Avatar
no i just put the tracker together and it started and ran fine b4 now itz just being a whore and if i dont start it for a day or so i have to use starter fluid but if i start it in the same day it starts just fine wut gives
Old January 28th, 2009, 11:59 PM   #12
cantafiof
drive hard and fast
Send a message via MSN to cantafiof
i had a 95 blazer that would only start if i put gas of starting fluid i replaced the fuel pump and then i never had trouble again
cantafiof is offline   Reply With Quote
Old January 29th, 2009, 12:01 AM   #13
Jb1986
Bowtie boy
Jb1986's Avatar
would the blazer stay running after u did that though kause i thought if the fuel pump was bad it wouldnt stay running i thought maybe im wrong
Old January 29th, 2009, 12:06 AM   #14
cantafiof
drive hard and fast
i sprayed the gas in and it started and i drove it there it was like there was no problem i though the same but after a few months of driving it like that it finally died and i was told by the dealer ship it was the fuel pump the whole time
Old January 29th, 2009, 12:08 AM   #15
jeeperbrian
GLFWDA member
because
Old January 29th, 2009, 12:10 AM   #16
CaptainBadAZZ
A.K.A. The Impact
It all depends on the state of the pump and regulator. I've replaced regulators that we're stuck 3/4 open which is fun to diagnose unless you take it out. Fuel pumps are generally more tricky due to variables. Poop dick gas, a rusting tank, rotting lines, maybe even just a bad batch of fuel can cause it let alone the fuel gelling due to cold weather.
Old January 29th, 2009, 12:12 AM   #17
Jb1986
Bowtie boy
Jb1986's Avatar
where is the regulator on them
Old January 29th, 2009, 12:16 AM   #18
cantafiof
drive hard and fast
idk could be on the pump i havent pulled that off my blazer the regulator is something i would go for first
Old January 29th, 2009, 12:17 AM   #19
CaptainBadAZZ
A.K.A. The Impact
This is a tbi right?
Old January 29th, 2009, 12:29 AM   #20
CaptainBadAZZ
A.K.A. The Impact
Default Stuff
I would make sure your pressure is good before start up. Ex. Key turned to run but not start and engine not running at all b4 that and check pressure. You could have fuel bleeding off.
Page generated in 0.33684 seconds with 83 queries
