DEI Autostart remote starter $50 firm plus gmdlbp bypass - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 28th, 2009, 04:42 PM   #1
BILL C.
** TEAM KAMIKAZE 4X4 **
BILL C.'s Avatar
Default DEI Autostart remote starter $50 firm plus gmdlbp bypass
brand new..........have 2 model :AS2272
The smallest 2-button transmitter on a long range remote control car starter. With 1500 ft/ 500 m of range, independent start and stop buttons are almost necessary. These buttons can also be configured to toggle lock/unlock and start/stop.
AM Technology - FM transmission technology
Manual/Automatic Transmission System - Supports both manual and automatic transmission systems.
Virtual Tach System - VTS is able to effectively monitor the vehicle starting sequence and release the starter at the right time without physically converting the Tach wire to the remote starter.
Unit Specific Features: Unit Specific Options: Starter Base Features: Starter Base Options:
Two 2-button transmitters
1500 ft / 500 m range
Monopole antenna with embedded red LED
Ignition controlled valet mode
Turbo mode
Idle mode
Cold weather mode
Virtual Tach System (automatic transmission mode only)
1 auxiliary output
Aux. 1: Horn or constant while pressed
Multi-speed tachometer learning
Normal and high tach jumper
Programming assistance button
Negative hood trigger input
Tachometer input
Auxiliary (-) ground output when running
Positive glow plug input
Gas or diesel engine compatible
Non-volatile system state memory
iDatalink compatible
Pager compatible
RS-232 port
INV-200 port
Configurable engine run time
3 minutes in gas mode / 8 minutes diesel mode
15 minutes in gas mode / 20 minutes diesel mode
25 minutes in gas mode / 30 minutes diesel mode
Turbo mode
Idle mode
Cold weather mode
Limited lifetime warranty
Dual 12-volt power wires
High-current outputs for Ignition, Accessory and Start
Configurable high-current output for 2nd ignition, 2nd accessory and 2nd start
Keyless entry outputs
Ignition controlled door lock
Trunk release output
Anti-theft starter-kill output
Passive or active starter-kill arming
Arm & disarm OEM alarm
Secure lock
Parking lights flash / diagnosis
OEM horn control
any other questions just ask..................trades welcome for samurai spare parts.
..also have gmdlbp bypass for most gm models from 1998 on up.....$40 firm
thanks
BILL C. is offline   Reply With Quote
Old January 29th, 2009, 11:53 AM   #2
BILL C.
BILL C.'s Avatar
BUMP..make offer
Old January 29th, 2009, 12:22 PM   #3
rhouser30
25 shipped
rhouser30 is offline   Reply With Quote
Old January 29th, 2009, 03:43 PM   #4
churd609
what would i need to make this work for a 07 silverado?
churd609 is offline   Reply With Quote
Old January 29th, 2009, 05:49 PM   #5
BILL C.
BILL C.'s Avatar
Originally Posted by rhouser30 View Post
25 shipped
no on the $25 shipped.......................look them up online before you lowball please........these sell for $139 plus install on the average at your local dealers.............i dont play games or try to make a bunch of money...i got a bulk buy on these and dont need this one..yes i may have paid less but its brand new,non refurbished............................fine,i will ship for $75 or you pay for shipping and buy it for $65..........
for the 07 silverado you need the 1701g data bypass.....ebay should have them for a fair price...that is a DEI product also (make viper,python,valet and hornet)......DEI bought out alot of companies lately due to copyright issues so they are huge.....
Old February 8th, 2009, 02:56 PM   #6
BILL C.
BILL C.'s Avatar
bump............make a decent offer.......................will be going to dog party in copemish so i can bring it then for any takers......................thanks
Old February 8th, 2009, 06:41 PM   #7
cameron69
dog farts are the worst!!
cameron69's Avatar
you have a pm!
cameron69 is offline   Reply With Quote
Old February 8th, 2009, 07:58 PM   #8
BILL C.
BILL C.'s Avatar
Originally Posted by cameron69 View Post
you have a pm!
thanks..........i responded.
if you have any other questions please ask...
Old February 24th, 2009, 05:34 PM   #9
BILL C.
BILL C.'s Avatar
bump for lower rock bottom price...................job fell through so i have 2 now plus bypass...........just want my money back so i can put it toward my zuk upgrades.....
i have 2 units for $50 each firm plus shipping which is lower than anyone can get them for by far.............plus the gmdlbp bypass for $40 firm plus shipping............
gotta move this stuf asap
thanks
Old February 28th, 2009, 09:19 AM   #10
BILL C.
BILL C.'s Avatar
bump
Old February 28th, 2009, 09:45 AM   #11
Jeepaholc92
Jeepaholc92's Avatar
would this work on a 92 1500 chevy
Jeepaholc92 is offline   Reply With Quote
Old March 3rd, 2009, 04:54 PM   #12
trprowen
trprowen's Avatar
any idea what i need to make this work on a 2002 silverado 2500 hd diesel 6.6L thanks
trprowen is offline   Reply With Quote
Old March 3rd, 2009, 08:01 PM   #13
BILL C.
BILL C.'s Avatar
yes, it will work..............you would need no bypass and if you dont have power locks or dont want keyless entry,you could have it put in your truck in about an hour.......................let me know.
Old March 3rd, 2009, 08:15 PM   #14
BILL C.
BILL C.'s Avatar
yes it will work..........you can use a variety of bypasses..........if you dont need door locks you can use a 555lw for the passlock 2 bypass......if you want doorlocks,i believe you can either get a combo bypass or you can use 2 relays to convert the polarity...................either way is not too hard........as far as the diesel options go, yes this unit will work with no extra part for the timer...it has a built in timer for diesel that can be programmed up to i believe 30sec. delay..........lt me know..thanks
Old March 6th, 2009, 07:12 PM   #15
BILL C.
BILL C.'s Avatar
Bump
Old March 29th, 2009, 10:50 AM   #16
BILL C.
BILL C.'s Avatar
Bump
Old August 8th, 2009, 11:39 AM   #17
BILL C.
BILL C.'s Avatar
bump............gotta sell em......make DECENT offer....
Old August 8th, 2009, 11:52 AM   #18
BILL C.
BILL C.'s Avatar
package deal price..........2 starter units and 1 gmdlbp bypass.......first $100
shipping extra....
thats -/$34 per item which you cant get cheaper anywhere else..especially for the bypass......thats $47 plus shipping on ebay for the Omega DL-GMDLBP......
thanks...
also still will trade for or toward a 1.6 8v or 16v for my sami.
Old August 28th, 2009, 01:03 PM   #19
BILL C.
BILL C.'s Avatar
1 left......................
Old September 22nd, 2009, 04:41 PM   #20
BILL C.
BILL C.'s Avatar
bump for winter.................have one unit plus the one bypass.....will entertain all offers on a package deal or individual.........thanks
Page generated in 0.47690 seconds with 83 queries
