A4LD help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2009, 08:04 PM   #1
Default A4LD help
1993 explorer Limited
fluid full nice and red and no codes and no check engine lamp
From a stand still in 1st or reverse it will slip then engage gear and move....once moving the truck runs and shifts beautiful 1-2 2-3 3-4 are all nice and smooth. Only while at a stand still trying to get it going does it have problems.
I have my other trans ready to go in at work tomorrow but just throwing it out there if their might be an easier fix or stupid item causing this symptom.
Old January 26th, 2009, 08:53 PM   #2
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
did you check the vaccum modulator on the side of the tranny? i had problems with mine and it did the same thing but i was losing fluid slowly.
Old January 26th, 2009, 08:55 PM   #3
did you replace it and it work normal again? I know those will leak fluid into the line and suck it into the intake.
Old January 26th, 2009, 08:56 PM   #4
bigblockford79
Big Block Ranger
bigblockford79's Avatar
my wifes explorer did this spring and it ended up being a thermostat that was stuck closed. Don't ask me how a thermostat affects the trans but it had similar issues to what you described, and all I did was replace the t-stat and it has been perfect ever since.
Old January 26th, 2009, 09:24 PM   #5
94rangeron35s
bought a Jeep
yes it shited normal again.
Old January 26th, 2009, 09:25 PM   #6
i'll have to pull the line off tomorrow and see if it dripples
Old January 27th, 2009, 08:35 AM   #7
took vacumn line off mod and its pouring trans fluid out...waiting on the new one and gonna drive afterwards and see where i am at.
Old January 27th, 2009, 09:07 AM   #8
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
I know this isnt likely to be your problem John but I had a similar problem with my aod in the bronco, it turned out that the little gasket for the filter was missing allowing it to suck air then i d goose the gas and it would grab and go, what i get for letting someone else work on my truck i guess
broncobuddha is offline   Reply With Quote
Old January 29th, 2009, 12:20 PM   #9
94KOTA
Buy American!
94KOTA's Avatar
Send a message via AIM to 94KOTA
maybe EGR valve?? mine was doing the same thing...ended up being EGR valve stuck open...
94KOTA is offline   Reply With Quote
Old January 29th, 2009, 02:07 PM   #10
most 91-94 explorers did not have an egr....unless a new york or california made model
and the vac mod fixed it
Page generated in 0.25885 seconds with 53 queries
