2nd gen explorer SFA questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 25th, 2009, 12:00 AM   #1
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
Default 2nd gen explorer SFA questions
on a SFA swap i was just wondering how they handle on the street, if i swap my front axle it will see alot of street time
i am debating on coils or coil overs, what would be easiest and what would be the best handling? overall the plan would be
solid D44
4.88 gears
lockers
coils or coil overs
36'' tires
opinions are greatly appreciated
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old January 25th, 2009, 10:43 AM   #2
Bones
Bones's Avatar
www.explorer4x4.com
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 26th, 2009, 03:04 PM   #3
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Does it currently have coils?
(they changed the front suspension without really changing the body style ~95).
Old January 26th, 2009, 03:17 PM   #4
Bones
Bones's Avatar
2nd gen is torsion bar suspension
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 26th, 2009, 06:22 PM   #5
Captain Ledd
Ranger Addiction?
Ok then.
In my own humble opinion, coils would still be the best handling, buckets from an earlier TTB Ranger or Explorer or BII can work, and Coils from Cherokee's/TJ's/etc. will actually fit in the buckets. Some say they ride a little soft, so the alternative is early bronco lift coils from somewhere like Broncograveyard.com, Jeep coils are around 230/220ish PPI, EB coils are between 320-350ppi depending, and a stock Ranger coil is actually about 450-500ppi or more (way too stiff for solid axles).
It should ride fine with any decent shock, and be sure to keep an eye on all of the associated angles, which will be the biggest factor in determining how it drives down the street.
You're also going to need a steering box.
Alot of folks with torsion barred RBV's go for leafs up front.
Old January 28th, 2009, 11:58 PM   #6
what would you suggest for a steering box? i have heard of the older f150 boxes being swapped in. please. school me.
Old January 29th, 2009, 02:38 PM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
if you want to box the frame, a steering box and steering shaft from a ranger or 1st gen ex will work
I've heard of people using toyota boxes that mount on the outside of the frame rail as well.
Old February 1st, 2009, 05:04 PM   #8
Captain Ledd
Ranger Addiction?
I've heard that most Ford steering boxes are the same, from the TTB Rangers/Explorers/BII's, up to the F350's. And a wide range of years to boot.
Old February 7th, 2009, 01:24 AM   #9
awesome, thanks for the help guys
Page generated in 0.29001 seconds with 50 queries
