project can't make up my mind. F150 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2009, 01:48 PM   #21
98-S10-lifted
98-S10-lifted's Avatar
Originally Posted by masterbeatty View Post
lookin good when we goin to the mounds???
Probably in may. I wanted to head up to silver lake for a sat. and sun. in April most likely after my brothers wedding.
Plus I kinda need to do a tcase and then throw my 2" spacers in up front to level out the truck.
Originally Posted by ddeadserious View Post
Looks awesome, nice choice.
it was an awsome selection. exspensive rims and tires for under a grand
98-S10-lifted is offline   Reply With Quote
Old March 7th, 2009, 01:50 PM   #22
98-S10-lifted
I might head over to the 8 mile Parts galore to get a stepside bed for the truck and maybe find some less-crusty fenders and do some olive drab paint
Old March 25th, 2009, 10:56 PM   #23
98-S10-lifted
well a while back I cut the front bumper and moved it back to the stock position.
But I have found other problems, I have to do a steering gear, a t-case, either seals in the trans or a new one, fix an axle leak, shocks, trans crossmember possibly.
tomorrow I am checking out a junkyard for a t-case and posslbly a trans, and maybe paint it.
Old March 25th, 2009, 11:03 PM   #24
masterbeatty
masterbeatty's Avatar
i was at both parts galores on tuesday and the new one has more useable f series.
Old March 25th, 2009, 11:07 PM   #25
98-S10-lifted
I was at teh one on livernois a week or so ago and there was nice ass parts but some jackass destroyed teh parts trying to get em off.
Old March 26th, 2009, 11:37 AM   #26
Fraser
Fraser's Avatar
what are the t-case and the trans slippin or somethin?
Old March 26th, 2009, 12:21 PM   #27
98-S10-lifted
t-case is hard to put into 4H and I cant put it into anything else. and teh trans leaks like a bitch, its a manual and still works, just leaks.
Its a manual BW1356 t-case
Old March 26th, 2009, 12:22 PM   #28
98-S10-lifted
and the fluid ate teh mount bushing for the trans, so it flopps to the side in 1st and 2nd.
Old March 27th, 2009, 11:11 AM   #29
Fraser
Fraser's Avatar
that might be why the t-case is hard shifting. where is that trans leakin from? around the case or on the top? i think you might be able to pick up seals or something for the top
Old March 27th, 2009, 10:06 PM   #30
98-S10-lifted
I would have to check that, the whole thing is wet so I have to investiate.
Old March 27th, 2009, 10:09 PM   #31
98-S10-lifted
Well I painted teh truck today, still have to get a couple cans of flat black and go over teh tailgate again, but for the most part it doesnt look that bad.
gotta do a bumper next had to cut it to paint everything. Too much work to unbolt cause teh clips broke.
Old March 27th, 2009, 11:21 PM   #32
masterbeatty
that looks tough.
Old March 27th, 2009, 11:39 PM   #33
98-S10-lifted
definitely like it better than the red. It took forever too. started around 11 and finished at about 5
Old March 27th, 2009, 11:55 PM   #34
masterbeatty
yea same with myne. ha. i didnt do much in the way of prep. i figured with new quaters and new front fenders will come different paint.
Old April 9th, 2009, 08:02 PM   #35
98-S10-lifted
well I finally got the pinion seal in after putting it off for so long. Cleaned up the trans, and found out I might just need to get a newish tail shaft housing. Then I was messing with the 4x4 shifter linkage, I found the problem and was extemely corroded. I then accidentally broke it but got it to work goo but then broke in another place, so I have to get a new shifter mechanism. Then I steering gear. Just might end up keeping it now.
Old April 10th, 2009, 11:51 AM   #36
98-S10-lifted
went to the junkyard to get a new steering gear but ended up buying a passenger fender and a door for my dads truck. Going to work on getting new er less rusted parts and get a decent paint job done.
Old April 11th, 2009, 10:17 AM   #37
98-S10-lifted
Well I got another fender, so I have newer fenders to throw on the truck. They have a couple of small dents but are way more solid than the ones I have on now. Next I will be looking for a new bed. I kinda want to get a step side but I want the same amount of room as the regular bed so it will probably another one that same as mine now. Then I will be cleaning all the paint off to or close to bare metal and paint it a darker red.
And I think I have a weird transfer case shifter mechanism because I cant seem to find one like mine in the junkyards.
Old April 25th, 2009, 03:06 PM   #38
98-S10-lifted
Got my steering gear in, it doesnt leak and is a lot more responsive.
Been thinking about throwing a 79 Bronco/F150 D44 under the truck with either 6" or 8.5-9" lift coils from jeff's bronco graveyard. probably leaning more towards the 8.5-9" coils and some 39" tires.
Old April 25th, 2009, 03:14 PM   #39
kframe357
1983 Ford F-150
kframe357's Avatar
nice rims/tires. what did they set you back?
kframe357 is offline   Reply With Quote
Old April 25th, 2009, 10:51 PM   #40
98-S10-lifted
Thanks
I ended up getting them used/ but in new condition for $950
Page generated in 0.38771 seconds with 83 queries
