TTB Dana 35 swap stuff - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 18th, 2006, 09:50 PM   #1
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Default TTB Dana 35 swap stuff
To those who have done it or know about it, how much would one expect to pay for a complete swap? (including radius arms)
is there any year or model difference?
particular options that were offered I should look for?
Case differences? I'm going to be running 4.56's in it.
And just to make sure, any year will have the 5x4.5 bolt circle correct?
Old May 19th, 2006, 02:45 PM   #2
88mudder
In the band!
as far as a price i have no idea.
im almost positive that all d35's from rangers and broncoII's were the same from 1990-1992. the explorer d35's may be the same but not positive
i know they offered 4:10 gears with limited slip. thats the best one they offered.
ive heard many ppl swap to 4:56's so it shouldn't be a problem
i know 100% that a d35 out of a 1990 broncoII has 5x4.5 bolt pattern.
hope this helps.
Old May 19th, 2006, 03:29 PM   #3
Captain Ledd
Ranger Addiction?
Sweet, thanks a bunch.
I was looking at one earlier today from a '93 Eddie Bauer Explorer (hope it has the fancy LS).. I figure my truck is rigged enough as it is, I should be able to make it work.
Old May 23rd, 2006, 05:31 AM   #4
88mudder
In the band!
therangerstation.com has tons of d35 swap info!
Old November 13th, 2006, 09:43 PM   #5
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
D35 were offered in some late 90s b2's, in late 90's - 97 rangers, and in all gen 1 explorer. I used one out of a 92 explorer about 1.5" wider, all are a direct bolt in. All use 5 on 4.5. Just dont do what i did and get the shitty 3.27 gears, look for on with 4.56s. Cheers Mike
Bronco Sally is offline   Reply With Quote
Old November 14th, 2006, 01:28 AM   #6
Captain Ledd
Ranger Addiction?
Actually it's allready in the truck, with some 4.56's on the carrier sitting on the workbench. Got mine out of a '95 Ranger, already had the manual hub conversion done
Old November 14th, 2006, 05:28 PM   #7
chris1044
chris1044's Avatar
yeah, you got lucky....some years ford made a 35/28 hybrid axle.....it's the 35 housing with 28 internals, and basically sucks
on a side note, did you buy into the "must swap case" to use 4.56's? I went directly from 3.27's to 4.56's and they fit right over the stock case - lotsa people claim there is a case break at 3.73, but there's not
Old November 14th, 2006, 06:07 PM   #8
Captain Ledd
Ranger Addiction?
I talked to a member called "porc", he gave me a pretty decent deal on the gears and seemed to really know what he was talking about. he checked on the split carrier thing but could only find one part #, so we decided I probably didn't need it. I had also heard of people going from the ratios you mention with no problems. Mine were 3.73's stock. I used The Ranger Station's faq to make sure I didn't get one of the hybrids.
Old November 14th, 2006, 06:26 PM   #9
chris1044
chris1044's Avatar
yeah, I got my gears from porc as well....best deal I could find hands down....and I also went with 4.56's....
Page generated in 0.24483 seconds with 50 queries
