what rear end in my '85 ranger - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 20th, 2009, 07:05 PM   #1
trx250r
302 powered
trx250r's Avatar
Default what rear end in my '85 ranger
i want to put a locker in my ranger and im not sure what to get. and if its a 7.5 do you think it will handle the 302 thats in it. how can i tell the difference between the 8.8 and 7.5
trx250r is offline   Reply With Quote
Old January 20th, 2009, 08:20 PM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
i believe the 85 would be a 7.5, any ranger with a 4.0 ford had an 8.8
The ranger 8.8 isn't really any stronger than the 7.7 as they share the same 29 spline shafts, larger ring gear though.
Old January 20th, 2009, 09:24 PM   #3
88mudder
In the band!
I run a Ranger 8.8 in my 302 powered Ranger and no problems, the larger ring gear is a good idea. 28 spline. I wouldn't put money into the 7.5.
Old January 20th, 2009, 09:26 PM   #4
I wouldn't put money in a 28 spline 8.8
to each their own
I have had 28 spline 8.8 shafts next to 31 spline shafts and the difference is way noticable as well as the axle tubes and the outer bearings in the housings as well.
Old January 20th, 2009, 09:37 PM   #5
88mudder
In the band!
get Explorer 8.8 if your going to spend all that money on a locker and you will never have problems. Ive had great results with added shim to the factory limited slip, this truck sees more street cuz its a DD.
Old January 21st, 2009, 06:50 PM   #6
trx250r
302 powered
trx250r's Avatar
im not in a big hurry, maybe ill see if i can find an 8.8 with a locker in it. yeah i used to drive my parents '93 explorer and the ol' 8.8 had 260,000mi and still felt good.
Page generated in 0.17824 seconds with 41 queries
