ford TTB balljoints - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 20th, 2009, 06:27 PM   #1
chevotass
chevotass's Avatar
Default ford TTB balljoints
any special tools needed to change upper and lower ball joints on a bronco ttb front end.
also any major issues people have run in to i should be ready for.
thanks.
Old January 20th, 2009, 06:31 PM   #2
spindle hub can be a bitch if its siezed on.....and whatever socket is needed for whatever style hub/bearing retaining nuts you have
Old January 20th, 2009, 06:38 PM   #3
88mudder
In the band!
large hammer and punch to drive the knuckle off
Old January 20th, 2009, 08:22 PM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
for the ball joints, a standard c clamp press is all you need.
Use a block of wood and a mini sledge if the splindle sticks.
A pickle fork is all you should need to get the knuckle off, only on the bottom joint.
Old January 20th, 2009, 09:11 PM   #5
chris1044
chris1044's Avatar
Meh, I simply use a long drift (piece of 1" dia copper) and a heavy hammer to pound the joints out of the knuckle.....no press needed
Old January 20th, 2009, 10:05 PM   #6
chevotass
chevotass's Avatar
sounds good. thanks guys
Old January 21st, 2009, 06:56 PM   #7
trx250r
302 powered
trx250r's Avatar
i know they make a special press that is pretty much a super heavy duty c-clamp with a hole in the bottom for the ball joint to fall out. they are handy because they can handle an impact wrench.
trx250r is offline   Reply With Quote
Old January 21st, 2009, 09:18 PM   #8
Yota Bill
if you want to borow the press, you can use mine
Old January 21st, 2009, 11:11 PM   #9
Fraser
Fraser's Avatar
so the do not use impact sticker is lying to me?
Old January 22nd, 2009, 07:48 PM   #10
chris1044
chris1044's Avatar
Don't know about others, but I ALWAYS use my impact gun with my snap-on ball joint press....who the hell (that does this for a living) uses a ball joint press by hand?? Hell, even the snap on guy was using one when he demo'd their new press a few years back
And BTW...the "no press needed" comment I made earlier applies to the removal of old ball joints - you'll need it to put the new ones in.....
Old January 22nd, 2009, 09:36 PM   #11
Yota Bill
never was one on mine, I've had it for years, in professional use, and never had an issue with using an impact...
only problem I ever had with mine was when I loaned it to somebody that said they knew how to use it...turns out he didnt...so he paid to get the parts replaced...
Old January 23rd, 2009, 11:21 AM   #12
BOGDOG
BOGDOG's Avatar
Might be true on the $30 Harbor Freight press.
I have had an OTC press for 25 years no problems. If you do not have an impact throw the ball joints in the freezer overnight they will go in easier.
Old January 23rd, 2009, 04:39 PM   #13
Fraser
Fraser's Avatar
thats what i had the c-clamp got bent during the install of a lower ball joint on a full size chevy
Page generated in 0.51175 seconds with 62 queries
