Need Some HELP!!!!! sound from jeep that makes you want to kill yourself - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 19th, 2009, 11:36 PM   #1
XJ90
Do Work
XJ90's Avatar
Angry Need Some HELP!!!!! sound from jeep that makes you want to kill yourself
There is a sound coming from my jeep which is a 2000 Jeep Cherokee 4.0I 5 door that makes me want to strangle someone. It comes on about 90 percent of the time but generally stops when i hit around 60 miles an hour and its not a sound from a belt or anything i checked that and switched out the serpentine belt...noise is still there...the odd thing is that every time i accelerate and hit the gas the noise stops. but when i let off the gas the high pitched squealing noise comes right back. also does it on the idle.
I had some suggestions of a high pressure vacuum leak but was unsure of where the leak would be..
ANY SUGGESTIONS!!!!!
XJ90 is offline   Reply With Quote
Old January 19th, 2009, 11:40 PM   #2
FlatFender
Tap Tap Splat
FlatFender's Avatar
You already posted this in the Jeep forum, no need to re-post it here.
Old January 20th, 2009, 12:08 AM   #3
knoch
knoch's Avatar
Send a message via AIM to knoch
That happened to me, it was the alternator going bad.
knoch is offline   Reply With Quote
Old January 20th, 2009, 06:57 AM   #4
PavementPounder
PavementPounder's Avatar
Yes. Don't make duplicate threads.
Old January 20th, 2009, 08:43 AM   #5
special ed
Pickup Agent
special ed's Avatar
Intake gaskets. Try tightening the manifold bolts first. Google "jeep whistling sound"
special ed is offline   Reply With Quote
Old January 20th, 2009, 09:18 AM   #6
Kid Rock
Does it make the noise when you are stopped at a light, or just when you are coasting? What about while you are braking?
Kid Rock is offline   Reply With Quote
Old January 20th, 2009, 09:19 AM   #7
Tom
Because racecar
Tom's Avatar
If i were you, I would just kill myself.......
Old January 20th, 2009, 09:25 AM   #8
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
waterpump. a guy at work has the same problem and refuses to fix it.
Old January 20th, 2009, 09:31 AM   #9
PavementPounder
If I were everybody else in this thread (except FlatFender), I would go post in the real thread in Jeep Tech.
Old January 20th, 2009, 09:32 AM   #10
scrambled82
scrambled82's Avatar
check your blinker fluid
scrambled82 is offline   Reply With Quote
Old January 20th, 2009, 09:36 AM   #11
karl214
You sure it's not the muffler bearings ??????
karl214 is offline   Reply With Quote
Old January 20th, 2009, 09:37 AM   #12
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
x2
Old January 20th, 2009, 09:40 AM   #13
JEEPR
Playing Possum
JEEPR's Avatar
Wife in the back seat?
JEEPR is offline   Reply With Quote
Old January 20th, 2009, 10:37 AM   #14
shouldabenacowboy
Hope and Change?
shouldabenacowboy's Avatar
Tried yelling at it in Spanish?
That cures it 90% of the time
SBC
shouldabenacowboy is offline   Reply With Quote
Old January 20th, 2009, 09:05 PM   #15
XJ90
Do Work
XJ90's Avatar
wow thanks for the suggestions...in response to Kid Rock....it does make the noise while at a stoplight or when i am stopped
Old January 20th, 2009, 09:08 PM   #16
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
pull the belt and see if it goes away....will narrow it down some at least.
Old January 21st, 2009, 07:56 AM   #17
special ed
Pickup Agent
special ed's Avatar
Can you not read? It's the intake gasket whistling try tightening the manifold bolts.
Page generated in 0.51009 seconds with 73 queries
