Beadlocks and anti-coning - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 18th, 2009, 07:51 PM   #1
Default Beadlocks and anti-coning
anti-coning rings overrated or what
I understand the reason/purpose, but without using some type of anti-coning ring is it really that bad or necessary to use them? Looking for expeirenced opinions.
Old January 18th, 2009, 08:02 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
they are very easy to make with a piece of 1/8 inch by 1/4 from tsc.
well worth the time and money
Old January 20th, 2009, 03:53 PM   #3
peice of what?
Old January 20th, 2009, 04:23 PM   #4
I've been running weld on beadlocks for 4 -5 years without coning rings with zero problems.
Old January 20th, 2009, 04:24 PM   #5
Bones
Bones's Avatar
it depends on the size of your outer ring. I do not run a coning ring, but my outer ring is large enough to prevent coning
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 20th, 2009, 04:24 PM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
same here
http://www.apalansing.com/
Old January 20th, 2009, 04:39 PM   #7
what kind of bolts?
grade 5
grade 8
stainless
I ordered the simple style from Ballistic Fab 15" rim, so the outer ring is .250" thick but not very large as far as inner dia.
Old January 20th, 2009, 08:11 PM   #8
grade 5s are fine, 20-ish ft-lbs.
I don't run anti-coning rings. They do cone up somewhat, doesn't matter. Doesn't cause leaks, Nobody is breaking bolts.
Old January 20th, 2009, 08:15 PM   #9
grade 5 with antiseize.
Old January 20th, 2009, 08:42 PM   #10
Bones
Bones's Avatar
I broke about 15 or so last season running rocks (grade 5)
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 20th, 2009, 08:57 PM   #11
1TFROT
1TFROT's Avatar
Originally Posted by junk90xj View Post
same here
me too. grade 8 stuff.
1TFROT is offline   Reply With Quote
Old January 20th, 2009, 09:02 PM   #12
then you should get a thicker outer ring and countersunk bolts.
Old January 21st, 2009, 05:54 AM   #13
I have 24 grade 8 bolts torqued to about 25 ft/lb.
Old January 21st, 2009, 07:00 AM   #14
Bones
Bones's Avatar
or just stock bolts in the trailer. Even with 3 or 4 bolts missing per wheel, it doesn't leak too fast
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 21st, 2009, 07:11 AM   #15
hosejockey4506
Visiting Admin
peice of what?
metal
you lay the metal on edge on the inside circumference of the inner ring. 1/4 inch tall 1/8 material.
start by tacking the end of the straight piece then bend it a bit then tack bend and tack
it took about 10 minutes a wheel with some one bending and one person tacking. we didint even use any heat just bent it. worked out very well.
Old January 21st, 2009, 08:19 AM   #16
95geo
newbie
95geo's Avatar
like hoser said, it's easy to do and the pros out weigh the cons... most importantly it keeps the crap from building up between the 2 rings... I have also heard of people using a "V" belt also.. that seems pretty easy and almost the same benifits.
Old January 26th, 2009, 03:02 PM   #17
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
what kind of bolts?
grade 5
grade 8
stainless
I run grade 8 bolts with no problems. I replace all the bolts every spring, they see a lot of stress, and they're cheap (by the pound at Tractor Supply).
Old January 26th, 2009, 04:33 PM   #18
hosejockey4506
Visiting Admin
haha alot of stress
how tight are you running them there supposed to be like 25 ft lb.s
Old January 26th, 2009, 06:28 PM   #19
BigBlockBlazer
Axle breakin' 101
Originally Posted by hosejockey4506 View Post
haha alot of stress
Stress = rocks, tree roots, doughnuts with 5 psi in the tires, etc. Ever been wheelin'?
Old February 2nd, 2009, 07:45 PM   #20
well got the rims all welded and the outer rings painted, stopped at TSC and got all the bolts etc....but didn't see anything for use on the anti-coning......they had quite a few empty bins when i was in not to mention i cleaned them out of bolts.....lol
Page generated in 0.31981 seconds with 83 queries
