95 f150 misfire, hard shift, won't start... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2009, 09:19 PM   #1
camccardell
tiger blood
camccardell's Avatar
Default 95 f150 misfire, hard shift, won't start...
ok this all started like 5 days ago. I was driving around and I was not able to accelerate. I started misfiring all over the place so I pulled over. With all the snow we have been having the coil on the fire wall was packed with slush. I cleaned it out and dried it out and stuck a gob of dielectric greas on it, and all was well.
2 days ago I was driving on the highway and I stared having random rpm's all over the tach. It went away after a few mins, and everything was fine again.
Today when I was leaving work, I started it and it immegiatly idled very high 1500-1700 rpms
It also shifted very hard into gear and into reverse. On the highway it could not pick a gear... it was all over the place.
I finally got home and let it set.
Well I went to go out again tonight and only made it about 2 miles. It was idling high again when I started it and it shifted very hard.
Finally stalled out, going down the road. Turned over very freely, but just wouldn't start.
Now it is hit or miss. It might start when I turn it over, or it might not at all. If it does fire, it tries to idle ofr about 3 seconds, then it starts missing.
Any ideas?
I am ready to shoot the damm thing
Chris
Old January 18th, 2009, 01:02 AM   #2
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
sounds like coil to me. if the engine isn't running at correct RPMs, it'll throw off shifting points for computer. i would start with changing that, look over wiring too
big_ol_bronco78 is offline   Reply With Quote
Old January 18th, 2009, 08:08 AM   #3
wdkdusters
wdkdusters's Avatar
x2
wdkdusters is offline   Reply With Quote
Old January 18th, 2009, 08:25 AM   #4
camccardell
tiger blood
gotcha, It is an msd so it should be under warranty.
I'll let you know
Chris
Old January 18th, 2009, 08:32 AM   #5
big_ol_bronco78
Psalm 40:2
yeah, keep us posted. this cold weather can be really hard on the electical/ignition.
Old January 18th, 2009, 09:54 AM   #6
camccardell
tiger blood
just went out and truned it over a few times.
It started then stalled like before.
2nd time it started right up and is currently running.
It is adjusting idle about every 20 seconds. It is going between 800-1000 rpms
should be about 600 I think
too scared to try to take it down the road again.
Old January 18th, 2009, 10:07 AM   #7
Nuggets
I fix stuff!
Nuggets's Avatar
I would start with inspecting the inside of your distributor cap. I would also look at the wires going to the pickup inside the distributor. Make sure everything is clean and dry. The next item I would look at would be the Throttle Position Sensor. The TPS can make a Ford do some crazy stuff when it's not happy. If this is an OBDI vechicle I doubt the ECM is causing the shifting problems. If you have a diagnostic connector under the dash it is an OBDII vechile and the PCM controls alot more of the trans functions and the tach for that matter.
Hope this helps out.
Old January 18th, 2009, 12:03 PM   #8
masterbeatty
masterbeatty's Avatar
i just replaced my tps on my bronco because it was shifting very fast and wouldnt hold out gears.it didnt shift hard just fast and it couldnt determine what it wanted to be in. and it also would not downshift.
but also check your vss on the rear end those will cause hard shifts i blew one apart once and it was a bad thing on a ride home from upnorth. as for the miss. nuggets couldnt have said it better. i ended up caucking my cap up and running a breather tube up the firewall with a tiny filter.
Old January 18th, 2009, 12:11 PM   #9
pigfat
GONE COMMANDO
pigfat's Avatar
Default possible vacuum leak
I second the tp sensor. Also check for a vacuum leak this will cause eradic idle also. Wouldnt hurt to check under the distributor cap and spray some silicone spray in there. Good luck.
pigfat is offline   Reply With Quote
Old January 18th, 2009, 12:14 PM   #10
camccardell
tiger blood
I just got back from the zone.
Tested the coil and it passed, but would be all over the place sometimes, so I bought a new one.
Took in the throttle body as well and tested the tps
it moves in the full range, so I think that is ok.
I'll be putting the coil on in a few, and I'll let you know
Chris
Old January 18th, 2009, 01:42 PM   #11
camccardell
tiger blood
put the coil on and it fired up. Ran for a little while the started sputtering and stalled. It will not start at all now. just turns over.
got a few codes off it as soon as it died
p1351
p1121
p0308
checkin on em
Old January 18th, 2009, 01:57 PM   #12
TurboChris
TurboChris's Avatar
Gotta say Iam glad that I dont have a ford after reading all your problems.
TurboChris is offline   Reply With Quote
Old January 18th, 2009, 02:35 PM   #13
masterbeatty
http://www.broncodata.com/tech/codes.htm
is the truck obd1 ? i assume it is. but none of those codes match anything i can find or have pulled off of mine.
Old January 18th, 2009, 02:41 PM   #14
masterbeatty
P1351 Ignition Diagnostic Monitor circuit Input fault
P1121 Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
and the last one is cylinder 8 misfire
Old January 18th, 2009, 03:18 PM   #15
jontboudrie
jontboudrie's Avatar
Default f-150
you could check the fuses also i think it's a 25 amp fuse when it blows it will have shift problem rpm's all crazy mine blows 3 times a year.it's the fuse panel inside the truck .
jontboudrie is offline   Reply With Quote
Old January 18th, 2009, 05:31 PM   #16
camccardell
tiger blood
well the truck was converted to obd2 last year when I made a custom harness.
just for shits, I unhooked the harness and took off the upper manifold, and re-pulgged in the old harness to the injectors.
It will now start, but that dosen't necessarily mean anything. I will hopefully be able to put it back together the rest of the way tommorrow, and road test it.
hey does anyone know the fastes or correct way to remove the computer?
I ask because I removed the seal for it, but there isn't enough room to pull it straight out. It hits the inner fender.
Thanks
Chris
Page generated in 0.28855 seconds with 71 queries
