05 King Quad stalling - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 16th, 2009, 12:18 AM   #1
89eliminator
cheesehead wheeler
89eliminator's Avatar
Default 05 King Quad stalling
My King Quad keeps stalling when riding through the snow. It runs perfect in neutral, but as soon as i shift into forward or reverse and give it gas, it will bog down and die. If i leave it sit for a while (couple of hours at least) it will start up and drive again. i know it has to be something with the snow getting packed in somewhere and getting something wet, because it runs a drives perfect in dry conditions. Has anyone had this problem before, and what are some areas i can check out?
89eliminator is offline   Reply With Quote
Old January 16th, 2009, 06:04 PM   #2
TOOLTIME
HMMM...did you check all hoses to and from carb. air intake, headside. airbox is good and tight, a snorkel somewhere didn't come loose, break etc???
TOOLTIME is offline   Reply With Quote
Old January 16th, 2009, 06:28 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
It is known to me that some quads are built with open connectors(not weather sealed) if you look around the quad see if you have the style I speak of. if so un plug the connectors and clean if nessary with a rifle brush and pack with dielectric grease to prevent this happening. I would bet if you look around the steering colume or under the seat you will the culprit.
Yetti
Old January 16th, 2009, 11:15 PM   #4
89eliminator
cheesehead wheeler
i have taken the body off, and gone through ALL connectors/connections, cleaned and put dielectric grease in them. i was thinking that maybe its a bad sensor???
Old January 17th, 2009, 07:18 AM   #5
Yetti
Yetti's Avatar
I wouldn't know where? The most I can see an electrical problem in wet or cold weather is from either grounding out or heat/cold expansion/contraction. the idea being that a part could effectivly crush its own contacts in cold weather and short. it does happen after its been running and would lend me to think that its a heat issue or wet issue. have you pulled your cdi box and looked at the case to see if the paint has burned spots on it? its just a long shot, but you never know.
Yetti
Old January 18th, 2009, 11:15 AM   #6
89eliminator
cheesehead wheeler
cdi is good.
another reason i was thinking a sensor was because when we had our first big snow fall of the year, i ran it and it never stalled once. About a month after that is when it started to stall on me.
Old January 18th, 2009, 11:41 AM   #7
gatesboy
will it start back up after it stalls if not check the spark if no spark then you have an electrical problem if you still have spark then its fuel or possibly the valves are in need of adjustment also drain some of your gas into a pepsi bottle and check for water
gatesboy is offline   Reply With Quote
Old January 18th, 2009, 12:28 PM   #8
swampfoxjr
Swamp Fox
swampfoxjr's Avatar
does it stall just after it gets warm? if so your choke might be stuck im a motorcycle mechanic and its hard to diagnose without being there. i just looked in a maual for that machine and there is not really any sensors that would stop it from running is your battery dead? if so your stator could be bad and that would cause it to run for a bit then stall, i would really go for a valve adjustment if is noisy
let me know if you need some help im work cheaper than a normall shop would charge
pm me
good luck
swampfoxjr is offline   Reply With Quote
Old January 18th, 2009, 08:24 PM   #9
89eliminator
cheesehead wheeler
i can run it all day in dry conditions. i live on some back country roads with minimal traffic and was driving those for about 30 minutes the other day no problems. but as soon as i hit the deeper snow, then it stalls out. Its usually a 50-50 kind of deal if it restarts or not. Sometimes it restarts, but will only idle. If throttle is applied, it will die.
The quad only has 600 miles on it, so i dont think the vavles would need to be adjusted. plus they arent noisy.
Also, to clears things up, this is a Fuel Injected quad.
The last time it stalled, i towed up to the shop and checked for spark. It did have spark.
Old January 18th, 2009, 09:20 PM   #10
TOOLTIME
hey 89...hate to question you, but did you check all your snorkel tubing and other things related to air intake? just wondering? also, 450 or 700??tim
Old January 18th, 2009, 09:24 PM   #11
motocrosstcw
motocrosstcw's Avatar
i would check all of your air intake hosing and housing for snow when water gets into the carbs it gotta get pulled out so its gonna take a while for the water to be sucked through so it has enough compound of gas and h2o to fire if theres to much water you end up with adead battery or sore leg lol but check you intake housing and stuff seal it all off and go at it again see if anything changes also check the boots on your cylinder from the carbs
motocrosstcw is offline   Reply With Quote
Old January 18th, 2009, 09:51 PM   #12
gmotox
gmotox's Avatar
check the vent hose for the fuel tank!!
Old January 18th, 2009, 11:08 PM   #13
89eliminator
cheesehead wheeler
well, i really didnt check them, but there is no water in the airbox. its a 700.
Old January 18th, 2009, 11:08 PM   #14
89eliminator
cheesehead wheeler
hmmm, havent done that yet.
Page generated in 0.47121 seconds with 65 queries
