Powerjoke no start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2009, 09:40 PM   #1
Toivo
Feel lucky?
Toivo's Avatar
Default Powerjoke no start
2000 PSD no start
-10 below
cranked this morning, batteries completely died.
replaced batteries AND starter relay today and still no crank no start.
jumped the starter with key in start position, cranked a few times, then no more crank, no start, just "clunks" out at fender mounted starter relay.
has good voltage to the starter and good voltage to relay.
any ideas would be helpful, Im not a diesel mechanic.
Old January 14th, 2009, 09:55 PM   #2
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Do you plug in the block heater or park inside? Diesels don't like cold. Might help. Also might be having a problem with the starter.
GNJEEPN is offline   Reply With Quote
Old January 14th, 2009, 09:59 PM   #3
Nuggets
I fix stuff!
Nuggets's Avatar
x2. My guess is your starter is toast.
Old January 14th, 2009, 10:09 PM   #4
Toivo
Feel lucky?
Toivo's Avatar
sorry its on a heater but thats not keeping it from starting
Old January 14th, 2009, 10:31 PM   #5
Bones
Bones's Avatar
sounds like a bad ground or weak cable
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 14th, 2009, 10:34 PM   #6
Bones
Bones's Avatar
Originally Posted by Toivo View Post
2000 PSD no start
-10 below
how long did you crank before the bats died?
see red above
Are you saying that the motor will not turn over when you turn the key, or it will turn over and just won't fire?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 14th, 2009, 10:38 PM   #7
Toivo
Feel lucky?
Toivo's Avatar
Originally Posted by Bones View Post
see red above
turned over approx 6 times.
I knew the batts were shitty, so I replaced them today.
Still no crank, no fire, no roll over, no nothing, just the sound of the starter relay on the fender clunking.
It DID roll over when I jumped the starter terminals on the starter, for a few times then just freewheeled.
I am 88% sure the starter is wasted.
Old January 14th, 2009, 10:42 PM   #8
Bones
Bones's Avatar
sounds like the starter, and those aint cheap
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 14th, 2009, 11:47 PM   #9
gmotox
gmotox's Avatar
weak batteries/low voltage will kill a good starter, I would check the grounds and cable to the starter though, if it cranked when you jumped the solenoid that would indicate a voltage problem or bad solenoid in my opinion. Clean all your battery terminals just for the fun of it too!!!
Old January 15th, 2009, 08:22 AM   #10
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Its your glow plug relay. mine went just after xmas, would crank and crank but wouldnt fire. I took a jumper cable and jumped the leads on the glow plug relay, waited 30sec and it fired right up.
I'm the man in White.
Old January 15th, 2009, 09:21 AM   #11
Icebreaker88
Icebreaker88's Avatar
He said it would not crank most likely starter like stated above or possible a bad connection at the starter
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old January 15th, 2009, 10:05 AM   #12
Skooter_Built
im retarded and dont read good.
Old January 15th, 2009, 02:42 PM   #13
Mclovin
"The Situation"
Mclovin's Avatar
hey i think your starter's bad
Old January 15th, 2009, 03:14 PM   #14
Bones
Bones's Avatar
just make sure your cables from the bat to the starter and bat to ground and engine to ground are not corroded and have good connections
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 15th, 2009, 03:45 PM   #15
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Also check the oil.
Old January 15th, 2009, 04:23 PM   #16
tom77cj5
tom77cj5's Avatar
it could be the starter
+300
Tags
diesel, fail, fords are junk, michigan sucks
Page generated in 0.37171 seconds with 71 queries
