Heavy duty t-case crossmember - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2006, 09:30 PM   #1
Pre4runner
Bike Dude
Pre4runner's Avatar
Default Heavy duty t-case crossmember
Well i bought some steel yesturday, went a little over board and cam back with a piece of 2x5 1/4" wall tubing and other stuff. Im going to make this into a tcase crossmember.
Whats your opinion?
Name:	86-89 toyota t-case cross member 2.jpg
Old May 17th, 2006, 10:22 PM   #2
Should definately be strong!
I'm running a Front Range Offroad center section on mine, custom arms, bushings at the frame. It transmits a bit too much vibration.
I'm going to be going flat-belly this summer, hopefully, or as close as I can get(my double adapter isn't clocked )..
My advice is to raise your drivetrain as much as possible.. every inch under there helps.
Old May 17th, 2006, 10:36 PM   #3
Pre4runner
Bike Dude
Pre4runner's Avatar
This alone will give 2 inches and keeps the drivetrain in its stock position. PLus it should be overkill and uses the stock mount for some comfort. Should be easy to mod when i do tuck the drivetrain... for now i just want it to run.
Still waiting on the machine shop for my block
Old June 2nd, 2006, 12:58 AM   #4
Pre4runner
Bike Dude
Pre4runner's Avatar
new plan.... same idea for keeping the stock mount only im keeping the tube flat and lifting the drivetrain
Old June 2nd, 2006, 06:59 AM   #5
nmeinc
Parts Galore Spokesmodel
nmeinc's Avatar
that design looks nice, but you may need to alter it as the front D-shaft wont clear. I am presently designing a Bootyfab Lo-pro crossmember and am running into that issue.
nmeinc is offline   Reply With Quote
Old June 2nd, 2006, 09:06 PM   #6
Pre4runner
Bike Dude
Pre4runner's Avatar
good point... im starting as soon as i get my engine back... its been almost a month at the shop....
I mihg tjust try it flat we'll see. Send me some pics of what your doing when you get to it
Old June 4th, 2006, 07:59 PM   #7
nmeinc
nmeinc's Avatar
well I made a lo-pro crossmember and here's what I came up with
it raises the T-case an inch and gives 3" more clearance than stock.
I retained the stock mount a for vibe control. slightly booty fab but it'll work.
made from 3"x" anlge iron, butchered and TIG'd back together. it is pretty strong as I picked the entire truck up by it.
Old June 5th, 2006, 12:01 AM   #8
Pre4runner
Bike Dude
Pre4runner's Avatar
looks like that will work pretty well. I think thats kinda how im going to go... maybe lift the t-case a bit more though... we'll see
Old June 5th, 2006, 08:36 AM   #9
nmeinc
nmeinc's Avatar
that is lifting the T-case against the floor and giving about "-1" clearance above, to go any higher you'd have to have a body lift or cut the floor.
you can see in the second picture how much the T-case is lifted.
Page generated in 0.21445 seconds with 51 queries
