Desktop Dyno - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2009, 10:15 AM   #1
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Default Desktop Dyno
Does anyone here have it and use it much? Is it worth the money to shell out for it? How about accuracy???
I'm putting a motor together and wanted to run through some different combinations and profiles, but wanted some feedback first....
Thanks!
Old January 14th, 2009, 10:32 AM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
its a neat program as you can put in different profile camshafts and see the changes in torque/hp and where the curve is. Is it 100% accurate, no.
Old January 15th, 2009, 03:06 PM   #3
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
anyone else have any imput on this???
Old January 15th, 2009, 05:26 PM   #4
merr6267
More boost than yours:)
merr6267's Avatar
Meh, don't bank on the actual HP numbers, but you may be able to see a some changes from one combo to another with an increase/decrease, but I've seen a lot of the numbers to be a little inflated.
merr6267 is offline   Reply With Quote
Old January 15th, 2009, 06:53 PM   #5
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
I wouldn't buy i. I used it when I built my stroker and no matter what I chaged I was only able to change the power numbers by +/-4. I'm sure its pretty close to what the motor is putting out, but it didn't change a lot based on valve lift, duration, stroke, intake.....
If you were closer I would let you borrow my copy.
Blue XJ is offline   Reply With Quote
Old January 15th, 2009, 07:00 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
I've been using the free Comp Cams set up. It seems relatively close and you can change most everything.
http://compcams.com/camquest/default.asp
Old January 15th, 2009, 07:27 PM   #7
IDIeselman
IDIeselman's Avatar
I would say if you put good information in you get some pretty good information out. I have Dyno Sim by Pro Racing Sim, it's almost identical to Desktop Dyno 2000 because they created the software for Mr. Gasket, it's just sold under a different name.
My "A" headed 598 in the real world made 995hp @ 7200 and 820tq @ 5900 on a DTS dyno, the software says 1005hp @ 7300 and 814tq @ 6000. That's pretty dang close. I created the airflow files for the heads when Charlie ported my heads, so good information is essential. Software is no replacement for the real thing but it is fun to tinker with and see what happens.
The camquest link posted above is relatively close but only offers off the shelf cams.
Old January 18th, 2009, 09:40 AM   #8
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Awesome! Thanks for the heads=up and the link. I've been meaning to check that one out, but have been too tied up lately to do it.
Old January 18th, 2009, 07:51 PM   #9
TsCuda
TsCuda's Avatar
X2. I built my 416 stroker in there first. It was lower by about 25 hp. Mostly due flow numbers on the heads.
TsCuda is offline   Reply With Quote
Old January 18th, 2009, 08:16 PM   #10
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Id say it is accurate with in 10%.
Old January 19th, 2009, 08:38 AM   #11
Cooter21
Im Rick James Bitch
Cooter21's Avatar
Tim, Your cousin Shaine has it on his computer at home right now. We have used it on a number of our race engines as a guide not the bible. It is usually within 9-14%. The new LS numbers will be tested by us this spring at Baker Engineering. A couple of our friends are registered for Pinks in July and they are going all out. I cant wait.
Cooter21 is offline   Reply With Quote
Old January 20th, 2009, 08:58 AM   #12
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Thanks Cooter! I'll catch up with him after I get my cam specs and see what we can get out of that thing....
Page generated in 0.33427 seconds with 58 queries
