Uverse question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2009, 01:23 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Uverse question
They are saying 4-6 hours for install, just wondering if any one know wtf would take 4-6 hours fro installation?
booblinker is online now   Reply With Quote
Old January 13th, 2009, 01:25 PM   #2
jeeperbrian
GLFWDA member
i just had mine done acouple months ago, didnt take that long. did they give you a 4-6 hour window or did they tell you it would take 4-6 hours?
Old January 13th, 2009, 01:26 PM   #3
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
My grandma had it done just a few weeks ago, took almost 3 hours but they ran all new lines for the cable/internet and the phone. They spend 30-45 minutes when they first get there just looking at things and where they can run lines etc...
Bronco351 is offline   Reply With Quote
Old January 13th, 2009, 01:26 PM   #4
booblinker
Sore and Tired 24/7
booblinker's Avatar
No they said they will get here between 12-2, and said 4-6 hours for install.
Old January 13th, 2009, 01:29 PM   #5
jeeperbrian
GLFWDA member
holy crap gayt&t gave you a 2 hours window?!? assuming they make it, thats amazing!
they will probably sit in their truck and walk around for at least 2 of those hours, then sit on the phone for another hour.
Old January 13th, 2009, 01:58 PM   #6
RockyMTN05
Cadillac pimpin
RockyMTN05's Avatar
Send a message via AIM to RockyMTN05
x2
RockyMTN05 is offline   Reply With Quote
Old January 13th, 2009, 04:01 PM   #7
Blue XJ
The Green Machine
Blue XJ's Avatar
Send a message via AIM to Blue XJ
Took over 9 hours to install it in my house. I think it was the persons first install. She wanted to use the cables that were already there. The box outside wasn't setup right, so the service guy came out, unhooked my neighbor from the pole, and hooked mine up then left. Mine still didn't work and neither did the neighbors. Guy came back, reconnected the neighbors, and put mine in a new connector, then left. Mine still wouldn't work, so he came back to test the line, found the connection was loose, fixed that and then left, still wouldn't work. They tried hooking up different hardware in the house but had to activate it first, still didn't work. Turned out the issue was I had a bad cable inside the house that wasn't compatible with u-verse, so the tech ran all new wires and it finally worked. Then had to go give my neighbor all new hardware cause they guy fried everything when he was outside changing wires.
They showed up at 8am on the dot, and left my house at 5:45.
Blue XJ is offline   Reply With Quote
Old January 13th, 2009, 05:40 PM   #8
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
a 4 room install of any "new" cable or sat system should be on average 2 to 3 hrs If done the right way
mideerslayer is offline   Reply With Quote
Old January 13th, 2009, 06:14 PM   #9
Sandals
Fucking Zen as Shit
Sandals's Avatar
running new wires took 1.5 hours
the completely dumbass installer who i eventually kicked out of the house and had his supervisor come fix it 7 hours.
basically the guy installing was a FNG and hooked up to he wrong thing in the box on the house, and connected to the incorrect port in the big fiber to copper junction box 2 houses down and couldn't troubleshoot it
Old January 13th, 2009, 06:32 PM   #10
5.9zj
5.9zj's Avatar
for those with uverse....how is uverse service? I have been debating trying it but have not heard enough satisfied customers to make the switch. Our neighbors got it installed last month and the tech was there all day long. There was also another van in front of their house the next day.
5.9zj is offline   Reply With Quote
Old January 13th, 2009, 06:34 PM   #11
jt269
GIRLPOWER
jt269's Avatar
mine took 8 hours had it done mon.
jt269 is offline   Reply With Quote
Old January 13th, 2009, 06:41 PM   #12
Sandals
Fucking Zen as Shit
Sandals's Avatar
No issues with mine. was installed end of september.
Only 3 complaints are
1) wish the guide was more like dish networks where you can set timers to automatically change the channel
2) Can only schedule and erase DVR'd shows at the main receiver, not the others in the house
3) only being able to watch/record 2 HD programs at once sucks, 3 would make me happy
Phone service has been solid, internet has been solid and faster than my previous ATT DSL
Old January 13th, 2009, 07:21 PM   #13
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Is the coax being installed just RG6, or some other type?
Old January 13th, 2009, 07:26 PM   #14
capone
capone's Avatar
I'm thinking about signing up for AT&T but i don't know which Internet speed I should get. Sandals which Internet speed do you have?
capone is offline   Reply With Quote
Old January 13th, 2009, 09:36 PM   #15
booblinker
Sore and Tired 24/7
booblinker's Avatar
does the cable go through like normal cable, or is it through the phone line too.
Old January 13th, 2009, 09:40 PM   #16
mideerslayer
NEVER GIVE UP!
its fiber optic to the outside box/pole and then rg-6 to the house and inside the house
Old January 13th, 2009, 10:16 PM   #17
Sandals
Fucking Zen as Shit
Sandals's Avatar
I have the "elite" speed (6.0 mbps), was thinking about moving up to the 18 (just because i can) but i dont think i would gain a ton, because usually i'm waiting on the server on the other end.
Old January 13th, 2009, 10:49 PM   #18
JeepRat
Infidel
JeepRat's Avatar
Had it 2 months now. Install took 4 hours. Have had lots of "pixelation" problems and image lockup with the TVs and after 5 "tech" visits still having the same problems. Now all 3 services randomly lock up and we lose TV phone and internet all at the same time. 3 of the 5 techs say its a problem with the copper lines from the house out to the main junction. 1 tech said we are too far away from the main junction. And 1 tech was/is totally clueless.
JeepRat is offline   Reply With Quote
Old January 13th, 2009, 11:01 PM   #19
JeepRat
Infidel
JeepRat's Avatar
they run a new 2 or 3 pair copper line from your phone network box on your house into a "residential gateway" which gives you the video/internet/voip signals all from the same box. There is no fiber optic run to the house, only the existing copper phone line(at least in Clarkston)
Old January 14th, 2009, 01:15 AM   #20
yellowjeeperman
The N3rd
yellowjeeperman's Avatar
When we got it installed at my parents house, they started at 9 or 10am and were there til almost 5pm. When they started there were only 2 guys, and towards the end of the day there were 5. Had to run 4 uverse boxes and hardwire them all in and had trouble running some of the wiring through the ceiling. Coolest part was it was a free installation.
Comcrap was there earlier in the week and some idiot that knew less about installations was there and had no idea what the hell he was doing and said our signal quality would suck because he had to run so much cable and it would cost us. We pretty much told them to GTFO and then ATT came. I'll never deal with Comcrap again.
Uverse is awesome, couldn't be better.
Check out this site if you have more questions about anything regarding uverse.
http://www.uverseusers.com/
yellowjeeperman is offline   Reply With Quote
Page generated in 0.33346 seconds with 82 queries
