2.9 ticking issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 12th, 2009, 10:55 PM   #1
deathbypsi
Brian R.
deathbypsi's Avatar
Default 2.9 ticking issue
I had a good scare today in my 90 Bronco2. Motor has over 150k on it but it runs like a champ,always dead quiet. Today while driving up I75 I had the radio up pretty loud and during the quiet between songs I heard a nasty ticking.I was doing about 75mph at 3200rpm. I let off the gas and started to pull off the highway and it started to go away. Before I could get off to the shoulder of the road it went away completely. I stayed in the slow lane doing about 60 mph {2800 rpm} for the next mile or two and everything was fine. I decided to speed up again and as soon as I hit 3000 rpm I could hear the ticking starting to come back,by time I got up to 75mph {3200rpm} it was back in full force.
My oil level was dead center on the cross hatch on the stick. Oil is 10/40 Penzoil that aint even got 500 miles on it. When I replaced the valve cover gaskets a while back the motor was spotless inside,no sludge at all.
On my return trip home I kept the truck under 3000 rpm and it never made a sound.
Sounds like a starvaton issue to me but I dont understand why. Anyone else run into this on a 2.9?
Old January 12th, 2009, 11:00 PM   #2
88mudder
In the band!
high mileage 2.9's do this all the time. Mine does it all the time on the highway and at startup. I use 10w30 and a quart of Lucas, it helps alot. You cant kill a 2.9 until you run it out of oil..trust me.
Old January 12th, 2009, 11:01 PM   #3
Bronco Ollie
Captain Jack Sparrow
Bronco Ollie's Avatar
all 2.9 tick it's called a lifter tick some you can adjust and other you can't
Bronco Ollie is offline   Reply With Quote
Old January 12th, 2009, 11:02 PM   #4
Bronco Ollie
lol that's a lie we ran one for an hour with no oil every time taking off in first gear we would shift at 7 grand and it wouldn't die
Old January 12th, 2009, 11:08 PM   #5
88mudder
In the band!
thats badass!! We ran a 2.9 with no fuelpump and no gas tank it kept goin strong for the 5-10 mins we ran it, Offroad86b2 is the guys name on here, Brad.
Old January 12th, 2009, 11:10 PM   #6
Bronco Ollie
they are hard to kill we only killed one we kept the pedal to the floor in first gear and then we heard this huge pop and then the motor would run anymore
Old January 12th, 2009, 11:10 PM   #7
Bronco Ollie
Like mudder said put some lucas in it and it will help it a lot
Old January 12th, 2009, 11:15 PM   #8
88mudder
In the band!
Change the oil asap. Keep that thing running as good as u can. 2.9's are torque monsters down low and into the mid range and yet get good MPG.
Old January 12th, 2009, 11:33 PM   #9
deathbypsi
Brian R.
deathbypsi's Avatar
The oil is fresh.Its has three oil changes in the past 1500 miles!
I understand these motors tick a little but why would mine seem to be rpm sensitive?
Old January 12th, 2009, 11:34 PM   #10
special k
special k's Avatar
lifters? possibly?
Old January 12th, 2009, 11:39 PM   #11
Bronco Ollie
the tick comes and goes like sometimes i will start mine up and will have no tick and then it will start to tick then it will go away it's the lifters and you can only adjust 84-88 ones the 89 and 90 one's are not adjustable
Old January 12th, 2009, 11:42 PM   #12
88mudder
In the band!
same with mine, once i get it up passed 2,500 and hold it for awhile on the highway the tick will come and it will go away after a while. I haven't tried adjusting mine yet..
Old January 13th, 2009, 01:27 AM   #13
fordman95
1 bad 390
fordman95's Avatar
Send a message via MSN to fordman95 Send a message via Yahoo to fordman95 Send a message via Skype™ to fordman95
i ran into the same problem on my 88 ranger i had a while ago. i tore the motor all down trying to figure out what it was and when i got to the bottom end i finally figured out what the cause was. even though the top of the motor looks clean chances are your oil pump screen is partially plugged and starving your motor for oil at around the 3000 rpm range. if you want to keep that motor running as good and long a possible i would clean the screen or change the pump and screen. i had that same problem on three of the four motors i blew up in it so i would try that before you end up having to by another motor for the sake of a 50 dollar oil pump.
fordman95 is offline   Reply With Quote
Old January 13th, 2009, 06:41 AM   #14
deathbypsi
Brian R.
deathbypsi's Avatar
Thats kinda what I was thinkin. I have been trying to avoid pulling the motor on this truck but I guess not its time. My bellhousing bolt holes for the starter are stripped,oil pan is coated in JB weld cuz its rusted so bad.....now this.
BTW, welcome to the site.
Old January 13th, 2009, 09:57 AM   #15
mudbillyredneck
mudbillyredneck's Avatar
x2 on the oil pump pickup..or worn out pump..
Gotta love the JB weld for the ford pans...
mudbillyredneck is offline   Reply With Quote
Old January 13th, 2009, 10:04 AM   #16
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
You can just buy my 2.9 in the parts section to get a better oil pan
fordlovinfarmer is offline   Reply With Quote
Old January 13th, 2009, 05:29 PM   #17
deathbypsi
Brian R.
deathbypsi's Avatar
I will be doing a 4.0 swap come spring anyway.
Old January 15th, 2009, 03:19 PM   #18
deathbypsi
Brian R.
deathbypsi's Avatar
Well my JB Weld oil pan fix gave up yesterday so with one quart of oil on my shop floor I have no choice now but to pull the motor this weekend to change the pan and pump. Hopefully I will find the screen plugged too so I know I have found my other problem.
Old January 15th, 2009, 03:23 PM   #19
88mudder
In the band!
you shouldnt have to completly remove the engine, ive always undid the motor mounts and lifted the engine up as high as i can go to get enough clearance under neath. Also 1 piece Felpro pan gaskets make it really easy to do if you leave the engine in there.
Old January 15th, 2009, 03:57 PM   #20
deathbypsi
Brian R.
deathbypsi's Avatar
What about the exhaust,trans and other lines?
Page generated in 0.40658 seconds with 83 queries
