Need Help New to working on yotas - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 11th, 2009, 06:21 PM   #1
fordman20042008
Jeb
fordman20042008's Avatar
Default Need Help New to working on yotas
Today i was playing around out back and got stuck then he pulled me off the hill while i was in four wheel drive the passenger tire locks up. Then when i unlock the hub it rolls fine what did i break im new to the toyota's dont have a clue on what im doing with axles on them thanks for whoever could help me out cause there is a snow run i have planned to go to in feb.
fordman20042008 is offline   Reply With Quote
Old January 11th, 2009, 08:20 PM   #2
ELFJ40
I like sparklers
ELFJ40's Avatar
What kind of Toy?. Solid axle front? Assuming so sounds like possibly a broken birfield, again depending on the year. Like pre 1985...
ELFJ40 is offline   Reply With Quote
Old January 11th, 2009, 09:35 PM   #3
fordman20042008
Jeb
yea solid front end thats what i figured that it was a broken birfield is that what u think or do u have other suggestions and are they are to change im used to working on ford and chevys
Old January 11th, 2009, 09:56 PM   #4
mudddtoy
mudddtoy's Avatar
broken birf,the first one might be tough but after that u could do them on the trail
mudddtoy is offline   Reply With Quote
Old January 11th, 2009, 10:06 PM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
You should give up right now and sell the truck to me really really cheap.
Old January 11th, 2009, 10:11 PM   #6
fordman20042008
Jeb
2000 u can have it
Old January 11th, 2009, 10:20 PM   #7
spr_chicken
spr_chicken's Avatar
Send a message via MSN to spr_chicken Send a message via Yahoo to spr_chicken
its probly the birfield with those big tires you are going to break alot of them
35'' or bigger just rips them apart
i might have an extra set of axles but i would save up for an eliminater kit or bigger axles
spr_chicken is offline   Reply With Quote
Old January 11th, 2009, 10:37 PM   #8
fordman20042008
Jeb
where is a good place to get birfield
Old January 11th, 2009, 10:48 PM   #9
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
Longfield's are the best aftermarket axles for the Toyota axles. $600 for the set, and $65 for each hub gear that you'd need in order to qualify for the lifetime warranty.
Old January 11th, 2009, 10:51 PM   #10
fordman20042008
Jeb
be better off buying some 3/4 tons or 1 tons almost huh where is a good place to buy bifs though anyone
Old January 12th, 2009, 12:12 AM   #11
Rebel2345
Rebel2345's Avatar
Well for around 800, you'd have an axle nearly as strong as a Dana 60 (So they say), or you could go for the good 1tons that normally sell for that much a piece. But depending on how or where you wheel, you could get away with 3/4 tons. But then you're doing custom drive shafts and steering and all that stuff.
The rear axle is already as strong as you should need. A lot of guys I've seen running the bigger tires on rocks and all that havent even done anything to the rear except gears and welded spiders/locker.
Old January 12th, 2009, 12:25 PM   #12
BOGDOG
BOGDOG's Avatar
I have some spares lying around.
Old January 12th, 2009, 01:27 PM   #13
ELFJ40
I like sparklers
ELFJ40's Avatar
Replacing a birf is a messy job. If it were me I would look at replacing all the seals and rebuild the front axle at the same time since your all ready that deep in.
Its a matter of how hard you wheel I suppose. Full throttle and turning the wheels all the way to one side or another will increase your chances of breaking one. Bigger tires doesnt help either.
If your easy on the skinny pedal you can do fine with 35s and stock birfields. A locker also adds to the stress on them.
Anyway. Longfields are the way to go if you have the $$. Do it one time and be done with it.
Old January 12th, 2009, 07:40 PM   #14
fordman20042008
Jeb
how much would u sell one for bog dog
Old January 12th, 2009, 07:41 PM   #15
fordman20042008
Jeb
yeah i want to turn it into just a nice all around trail rig i would like to find some 35 inch boggers to trade these 42's for
Old January 12th, 2009, 09:29 PM   #16
J/T
J/T's Avatar
Send a message via Yahoo to J/T
just a quick question, what run are you planning on doing in feb.
J/T is offline   Reply With Quote
Old January 12th, 2009, 09:33 PM   #17
fordman20042008
Jeb
rocks and valleys
Old January 12th, 2009, 11:11 PM   #18
Nuggets
I fix stuff!
Nuggets's Avatar
Originally Posted by fordman20042008 View Post
2000 u can have it
Dammit, too many zeros!
Page generated in 0.26729 seconds with 77 queries
