Front Lock Right and winter driving Can I do this? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2009, 08:27 PM   #1
The-Bear
Supercharged Santa-Bear
The-Bear's Avatar
Default Front Lock Right and winter driving Can I do this?
When I drive my 1994 Supercharged, nv4500 tranny, Atlas 2 transfer case,Trac-Loc dana 30, 32" tires YJ, on slippery roads the front Lock Right locks and unlocks the front as needed. This can make for a wild ride to say the least. Having one or the other side lock and unlock pulls the the Jeep from side to side . Hit the gas it pulls right, let off pulls left. The Jeep has the stock front Dana with the vacuum disco in it. If I were to take the transfer case out of 4 wheel and disconnect the vacuum hoses and plug the ports on the vacuum disconnect so the passenger axle shaft spins free. This way I will only have power to one wheel.
1. Will this cause problems for the Lock Right?
2. Do you think this will cure the problem of being pulled from side to side or will it still do it. only on one side?
What do you think?
Bear
The-Bear is offline   Reply With Quote
Old February 6th, 2009, 06:35 PM   #2
Jrod-13
poser wheeler
no, that would make it worse, dont drive in 4wd
Jrod-13 is offline   Reply With Quote
Old February 7th, 2009, 08:58 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
lockers are for off road. they suck on the street in the winter! use 2wd
Old February 7th, 2009, 10:24 PM   #4
badazzamc
Get Some
badazzamc's Avatar
yup
Old February 9th, 2009, 10:42 PM   #5
jeepman784
Now pedals a bicycle
jeepman784's Avatar
Send a message via AIM to jeepman784
use 2wd and then 4wd i you go into the ditch... when it gets squirly, point toward some nice soft snow, cause a slowdown as people watch you drive out
jeepman784 is offline   Reply With Quote
Old February 10th, 2009, 01:01 AM   #6
PavementPounder
PavementPounder's Avatar
What do you think?
Bear
I think you're lying, as you clearly said you had a
Trac-Loc dana 30
And then you asked a question about your
Lock Right
I also think that
doesn't matter when considering the question, except for the Trac-loc part.
Page generated in 0.25055 seconds with 41 queries
