95 explorer sport regearing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2009, 04:45 PM   #1
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
Default 95 explorer sport regearing
im putting on some larger tires in the near future, and was wondering what gear ratio should i be running in the front and rear? the tire size im considering is a 36" tire any helpful info would be great
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old January 9th, 2009, 04:50 PM   #2
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
4.88 at least.
Arnie897 is offline   Reply With Quote
Old January 9th, 2009, 07:35 PM   #3
86scottsdalek10
86scottsdalek10's Avatar
well to get back to your stock gearing with a 33" tire and you had a 235/75/15 stock then it would require you to be around the range of 4.88's but you need to tell us your stock tire size as well...and what your looking at getting out of it....is it a dd or a play truck? and do you want to drive it on the eway or do you want more low end out of it...there is alot of things to consider. therangerstation.com has a section under the tech articles or forum i believe that has a calculator for tire size. try that
86scottsdalek10 is offline   Reply With Quote
Old January 9th, 2009, 07:58 PM   #4
im still running IFS and dont plan on changing it out, right now it feels like it has gears in it, im running 33's currently.. not really sure what gears are in the front and wouldnt know how to check, the back is the same way except i know how to check that...its more of a DD than anything else, it runs in sand/light trails and water crossing mostly...id like to keep the milage about the same. i already have a decent amount of giddyup with the throttle body and intake..if it makes a difference.
i really would like to get it back close to stock gearing but will look at the possibility of more low end
Old January 9th, 2009, 11:40 PM   #5
Old January 10th, 2009, 12:06 AM   #6
any idea of what Ring and pinion i'd need to use in the front?
like what "axle" is it? lol
Old January 10th, 2009, 11:18 AM   #7
86scottsdalek10
well i have no idea as far as ifs....i was thinking you had an i beam setup but call your local ford dealer to get that question answered unless someone else chimes in on here with it.
Old January 10th, 2009, 12:13 PM   #8
front is still a D35 (just make sure when ordering you get the right D35 year gears) and the rear is just the plain jane 8.8
Page generated in 0.21674 seconds with 47 queries
