Snowmobile Electrical problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2009, 12:46 AM   #1
mikeswmikesweat73
Crazy
mikeswmikesweat73's Avatar
Default Snowmobile Electrical problem
I have a 94 ski-doo Mach 1 that starts in a pull or two when cold, runs and drives great. Here's the problem, it shut off on me one time last winter and wouldn't start back up for about an hour. And last weekend it started great drove it for 25-30 minutes and I shut it off, tried to start it back up about 10 minutes later and it just wouldn't fire up for anything. Usually once it is warm it fires right up with about 1/4 pull. About an hour later went out and primed it a few times like I normally do when it is cold and it fired right up. Sounds like maybe something elctrical is heating up and malfunctioning.
Any ideas? I am going to look through the wiring for corrosion I had a similar problem with my KLR 650 and it trurned out to be nothing more than corroded wiring.
Thanks in advance,
mike
mikeswmikesweat73 is offline   Reply With Quote
Old January 11th, 2009, 05:08 PM   #2
gomer1975
gomer1975's Avatar
hey you get your sled running yet?
gomer1975 is offline   Reply With Quote
Old January 11th, 2009, 05:18 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
It sounds like the ignition modual over heating. check to see if your voltage regulator is working, it might be running to many volts to the system.
Yetti
Old January 11th, 2009, 05:21 PM   #4
Bow_Extreme
Bow_Extreme's Avatar
I'm curious, what do your plugs look like? Reason being, if the carbs are out of adjustment or need a good cleaning, you can have issues similiar to this.
Bow_Extreme is offline   Reply With Quote
Old January 13th, 2009, 10:26 PM   #5
mikeswmikesweat73
Crazy
Sorry guys been away from the computer, it has started and ran fine since then. Plugs look good, I'm not sure how to check the voltage, I'll definetely figure it out though thanks for the advice. Got a new problem now, blew a hole through one of the pistons in the 1980 exciter I bought a month ago. Like a jackass I took the airbox out and didn't change the jet and leaned the damn thing out. Anyway like I said thanks for the help.
Mike
Page generated in 0.22656 seconds with 38 queries
