interesting tire site - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 8th, 2009, 08:19 PM   #1
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
Default interesting tire site
I think they are retreads, look at the prices
http://treadwright.com/Tires-c2.aspx
fukkinrizzo is offline   Reply With Quote
Old January 8th, 2009, 08:30 PM   #2
billywilly92
billywilly92's Avatar
Yeah it says they are a retread company. But I think it would be good for a spare since they are so cheap.
billywilly92 is offline   Reply With Quote
Old January 8th, 2009, 08:40 PM   #3
swampfoxjr
Swamp Fox
swampfoxjr's Avatar
ive got a friend that has had retreads on his truck for over a year and no problems thanks for the site its in my favorites for the future
and a little side note almost every semi you see has re-treads
swampfoxjr is offline   Reply With Quote
Old January 8th, 2009, 08:44 PM   #4
smasheromalley
smasheromalley's Avatar
I dunno if Id put them on my tow rig - the site seems to have issues with giving them a load/weight limit.... id wheel them on any light truck, especially a wheeler.
Old January 8th, 2009, 08:49 PM   #5
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
been using there tires for a yr or so..love them..and have had no issues..
bigjay is offline   Reply With Quote
Old January 8th, 2009, 08:52 PM   #6
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
There are a few people on here, ecj5.com, and jeepforum that run or have run them. I have heard no complaints on them. I was going to buy the 37" size, but they have been temporarily discontinued.
Old January 8th, 2009, 08:52 PM   #7
Marion3
Marion3's Avatar
Treadwright used to be Hi-tech Retreads,
Ive heard of very little issues with their tires.
Marion3 is offline   Reply With Quote
Old January 8th, 2009, 08:54 PM   #8
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I used to sell Bandag recaps, they are done well. so if this place is as good they will out last the casing no problem.
Yetti
Old January 8th, 2009, 09:02 PM   #9
GetItOffroadGMC
GetItOffroadGMC's Avatar
Good find. Glad to hear the good reviews........Im thinking my new tires are gonna come from there.
Anyone know the diffrence between the regular ones and ultra?
GetItOffroadGMC is offline   Reply With Quote
Old January 8th, 2009, 09:04 PM   #10
bigjay
bigjay's Avatar
make sure when u order u ask for matching carcass..they tell ya may take longer for the order to ship but they seem to go out on time..
Old January 8th, 2009, 09:19 PM   #11
Marion3
Marion3's Avatar
Ultra grip
http://treadwright.com/images/Ultra%...tra%20Grip.pdf
Old January 8th, 2009, 10:32 PM   #12
Yota Bill
the ultra-grip basically has walnut shells mixed into the tread compund as a traction aid...
Old January 8th, 2009, 11:04 PM   #13
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
re-treading tires is not a new concept...... tractor's use them alot on drive tires. I'm sure Yota Bill and yetti (Rizzo, you should too!) know that though, given their equipment backgrounds.
Old January 8th, 2009, 11:07 PM   #14
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
They seem to be out of stock of everything.
Old January 8th, 2009, 11:14 PM   #15
bigblockford79
Big Block Ranger
bigblockford79's Avatar
The load rating will stay the same, the rating comes more from the sidewall and donor carcass construction. When they recap a tire all they do is grind the old tread down and vulcanize a new tread patch onto the carcass.
Semi tractors have been doing this for more than a decade and their tires have very high load ratings and a lot more road abuse than what your tow rig will. If recapping affected load rating in anyway there is no way the DOT would allow them to use them on the road.
Old January 8th, 2009, 11:25 PM   #16
Mclovin
"The Situation"
Mclovin's Avatar
if they had BIG sizes they'd be perfect for a trail rig
Old January 8th, 2009, 11:28 PM   #17
bigblockford79
Big Block Ranger
X1000/1000. I would already own a set if the came bigger.
Old January 9th, 2009, 12:32 AM   #18
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
http://www.greatlakes4x4.com/showthr...light=retreads
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old January 9th, 2009, 09:02 AM   #19
smasheromalley
Am I correct in that semi tractors cant run retreads on steer axle? That only leaves me with only 2 tires, not much in savings. Plus since fully loaded Im already pushing weight limits of new tires that are clearly rated - they might work just fine, but Id still not run them. Just MO
Old January 9th, 2009, 06:50 PM   #20
fukkinrizzo
IIRC no, your wrong. Personally I would not put them on a seer of a OTR truck, but a city truck would be ok. the 2 main reasons caps fail is because of a bad casing or low air pressure on the highway.
each person is entitled to there opinion about caps and they are not worth arguing over. Yes, I've seen guys arguing there merits.
Page generated in 0.38917 seconds with 82 queries
