XR 400 Timing Chain tensioner - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 8th, 2009, 07:35 PM   #1
chris1044
chris1044's Avatar
Default XR 400 Timing Chain tensioner
Posting this because my GF's brother doesn't know what he's doing.....he got a new chain tensioner, and pulled the pin prior to installing it into the motor. Have any of you had it apart?
There's a C-clip on the front side of it (where it goes into the motor), and i know I can try to take it apart, but if it's a massive PITA I'll just see if he can "return" it and get his $70 buck back .....because I'm sure all of you know, the second you take something apart and can't get it back together it's your fault
Edit: wow, helps if you read the manual (and helps if you don't listen to ppl who tell you they have)....would delete but I can't....
Page generated in 0.24905 seconds with 26 queries
