99 explorer t case - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 7th, 2009, 09:11 PM   #1
special k
special k's Avatar
Default 99 explorer t case
what t case comes in the 99 explorer with a 4.0L v6, automatic and electronic shift? it has the auto 4x4, 4x4 hi and 4x4 low? i think it's a borg warner, but unsure. any one know?
Old January 8th, 2009, 06:44 AM   #2
special ed
Pickup Agent
special ed's Avatar
BW4405. The usual problems are : shift fork pad wear, and the bosses where the shift rail sets in the case wear, then the range slider doesn't engage fully. This causes a "zing" sound on decelleration. GM big-end starter bushings fit the shift fork shaft, and I have a machine shop bore the case to accept the new bushings. There are no bushings at that location from the factory. Don't buy a used or rebuilt case, yours can probably be repaired.
special ed is offline   Reply With Quote
Old January 8th, 2009, 06:48 AM   #3
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
the V6 had the 1354E. the 5.0 used the 4405 and pretty sure thats full time or AWD
Old January 8th, 2009, 07:54 AM   #4
special ed
Pickup Agent
special ed's Avatar
Um, no. I have two of them on the bench now. One is a 98, the other a 99. Both BW4405's. Both V-6's, one is thw SOHC, the other the pushrod. The BW4405 is the "automatic" 4wd setup. It uses a magnetic clutch to activate a ball-and-ramp, to apply the 4wd clutch. It has a planetary low range.
Old January 8th, 2009, 09:20 PM   #5
special k
special k's Avatar
the problem he has with the current case is that it wont come out of 4hi. even in auto it wont shift outta 4hi. only way to get 2wd is takin out the front drive shaft.
Old January 10th, 2009, 08:00 PM   #6
special k
special k's Avatar
bump. any more ideas?
Old January 11th, 2009, 07:56 PM   #7
special ed
Pickup Agent
special ed's Avatar
The front output is engaged by applying a clutch pack. The clutch pack applies mechanically, with three balls in V-shaped grooves, or ramps. A magetic clutch, similar to an A/C compressor, is used to do this. Something is bound up, it has to come apart. They are not hard to overhaul.
Old January 11th, 2009, 09:08 PM   #8
special k
special k's Avatar
could it possibly be speed sensors at the wheels? i've heard something like that too?
Old January 12th, 2009, 08:08 AM   #9
special ed
Pickup Agent
special ed's Avatar
Unplug the harness at the t-case. If it goes to 2wd, it is an electrical problem.
Old February 16th, 2009, 09:28 PM   #10
special k
special k's Avatar
figured it out, he told be something about replacing clutches in the case and it works now. now the only prob is one of the 4x4 lights on the cluster will randomly start flashign? any ideas? gem module bad?
Page generated in 0.29818 seconds with 53 queries
