Ranger Smoking - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 6th, 2009, 06:31 PM   #1
lepp1892
WebWheeling1KeyAtaTime
lepp1892's Avatar
Default Ranger Smoking
So I did an oil change yesterday and today the truck is smoking really bad. It seems to be burning oil because its blue smoke. It's a 1992 4.0... any ideas of what to check...
The oil level was also slightly high... not a lot but a little bit over the full line...
lepp1892 is offline   Reply With Quote
Old January 6th, 2009, 07:59 PM   #2
lepp1892
lepp1892's Avatar
It seems that it might also be burning coolant too... I think it might be a head gasket but normally in a blown head gasket doesn't the oil get milky... Also it really only smokes when it is idling or when I get off the gas.
Old January 6th, 2009, 07:59 PM   #3
booblinker
Sore and Tired 24/7
booblinker's Avatar
Burning oil right after they did an oil change? Sounds like maybe to light of oil, or maybe they put synthetic in it?
Old January 6th, 2009, 08:00 PM   #4
Shotgun
I only wheel with boats.
Shotgun's Avatar
take the dipstick and drip the oil off of it on a hot manifold on another vehicle, oil will just burn, oil and water will dance while it burns. why do you think its burning coolant?
Old January 6th, 2009, 08:01 PM   #5
lepp1892
lepp1892's Avatar
It isnt synthetic. I changed it myself. Also the oil level isn't low on the dip stick. Its actually a little bit high which confuses me?
Old January 6th, 2009, 08:01 PM   #6
lepp1892
lepp1892's Avatar
The smoke kind of smells like coolant.
Old January 6th, 2009, 08:29 PM   #7
Shotgun
Shotgun's Avatar
try what I said to test it.
Old January 6th, 2009, 08:44 PM   #8
lepp1892
lepp1892's Avatar
alright... ill try that 2mara... thanks
Old January 8th, 2009, 10:21 AM   #9
lepp1892
lepp1892's Avatar
I did the oil off the dip stick on the hot steel thing... It danced a little bit but i figure that since i just did an oil change, it hasn't had a lot of time to get the milky color...
Old January 9th, 2009, 04:00 PM   #10
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
I would start testing for head gasket or head failure. Sounds like coolant in the oil which is affecting your oil level and also leaking into the cylinder.
Troll53 is offline   Reply With Quote
Old January 14th, 2009, 06:47 PM   #11
bikerted86
Did you run it much since you did the oil change, I screwed up one time and filled the oil too quick on a customers car and it filled up part of the intake tube and smoked alot after that (till i cleaned out the oil)
bikerted86 is offline   Reply With Quote
Page generated in 0.31545 seconds with 56 queries
