Universal pattern wheels - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 4th, 2009, 11:11 PM   #1
88mudder
In the band!
Default Universal pattern wheels
Rearend is 5 x 4.5 bolt pattern (8.8 out of a Ranger)
Frontend is 5 x 5.5 bolt pattern (d44 early bronco)
Im looking for a set of universal bolt pattern wheels so i dont have to buy 2 sets of different wheels and to avoid using adaptors..
Where to find these wheels? I currently have a set BUT the hub hole isnt big enough for 3 1/2" OD hubs.
*All i have found are expensive sets for drag racing only
Old January 5th, 2009, 01:47 AM   #2
F150hybred
Well versed in TTB
F150hybred's Avatar
Why not just use a set of adapters that go from the smaller to the larger. This way, you will be able to match up your track width on the rear to the front. Spider trax come to mind... great manufacturer. If I remember correctly, you will need 1" spacers for both to match track width... two inches total on the rear.
F150hybred is offline   Reply With Quote
Old January 5th, 2009, 11:18 AM   #3
Jdc215
Jdc215's Avatar
you might be able to get the centers bored out at a machine shop.
Jdc215 is offline   Reply With Quote
Old January 5th, 2009, 12:08 PM   #4
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Cheaper to swap the rear to 5 on 5 1/2"
Old January 5th, 2009, 09:14 PM   #5
88mudder
In the band!
yeah i think spacer adaptors is what im going to do, the wheels are 2 expensive for my budget right now. Thanks for the help guys.
Old January 5th, 2009, 11:24 PM   #6
F150hybred
Well versed in TTB
F150hybred's Avatar
Before you go and buy some adapter/spacers, be sure to measure the track of the wheels and divide the difference by two so you get the rite ones. IE: if the front is four inches wider than the rear, get 2" adapter/spacers. (and check for possible fender clearance issues too) <--- almost forgot that part!
Old January 5th, 2009, 11:26 PM   #7
88mudder
In the band!
yup thx
Page generated in 0.20160 seconds with 44 queries
