Daily Driver B2 project - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2009, 07:54 AM   #81
deathbypsi
Brian R.
deathbypsi's Avatar
Front end is almost done now.
Picked up some Skyjacker Softride 6" coils for a Jeep XJ.
I had to get new Jeep spring isolator pads since the XJ coils are not wound as tight on the bottom as a RBV coil.
Then I had to use some 1 1/2" plumbing fittings to make a new spring seat.
Here is how the new seat works without the pad installed yet.
And with the pads.
I also had to take the bottom plate that holds the bottom of the coil in place and build up its O.D. a bit with a few passes of my welder since it would pull right thru the bottom coil.Now the bottom is retained like the factory setup. For the top I took a 5/8 cable clamp and cut it into a J hook and then drilled a hole in the coil bucket for a solid way the make sure the top of the coil doesnt pop out at full droop.
Since these were 6" springs I had to cut 2 coils off to get the ride heigth where I wanted it.Nice thing is they sell different size isolator pads that I can use to fine tune the ride heigth in the future if I wish.
Going to get it aligned in a few and I will have them install my 4" drop pitman arm since my puller doesnt fit up into the frame for some reason.
I drove it around the block and holy **** does it ride soft now! Most people prlly wouldnt like it but I do. Its going flex alot better now. Next I will have to get longer shocks because the Duffs are about 1.5" to short to get full droop.
Old March 8th, 2009, 11:24 PM   #82
NewGuy
Nice, Now lets see A full shot of the B2 with the new front end! Does it sit even now?
NewGuy is offline   Reply With Quote
Old March 8th, 2009, 11:38 PM   #83
88mudder
In the band!
sweet!
Old March 8th, 2009, 11:40 PM   #84
deathbypsi
Brian R.
deathbypsi's Avatar
The rear is still a bit higher so I might try some thicker XJ coil spring isolator pads cuz I only used 3/4" Daystars.
Old March 9th, 2009, 12:01 AM   #85
NewGuy
Well looks alot better than before. I might be picking up something to build here real quick and maybe I can join you guys in som muding,LOL
Old March 12th, 2009, 03:37 PM   #86
deathbypsi
Brian R.
deathbypsi's Avatar
Well I had to put a 180 t-stat in it cuz its been running 230 when I wheel it hard and I also put a 10" fan behind the trans cooler to help when its just crawling around slow.
Old March 12th, 2009, 04:14 PM   #87
stinkpickle
bitter clinger
stinkpickle's Avatar
Nice fan. What'd that come off of? Today I just noticed my bent rear fender from wheeling last week. Must of hit pretty hard.
stinkpickle is offline   Reply With Quote
Old March 12th, 2009, 06:20 PM   #88
deathbypsi
Brian R.
deathbypsi's Avatar
I believe it is a old Peracool fan.
There is talk of going out again saturday morning if your lookin for more body damage.
Old March 12th, 2009, 06:26 PM   #89
stinkpickle
bitter clinger
I might want to go for some morning damage or uhh wheeling.
Old April 8th, 2009, 02:17 PM   #90
Jdc215
Jdc215's Avatar
what was wrong with the duff coils?
Jdc215 is offline   Reply With Quote
Old April 8th, 2009, 02:21 PM   #91
deathbypsi
Brian R.
deathbypsi's Avatar
They were wore out and sagging bad. In new condition thet have a 400lb spring rate which dont flex very good.I went with the XJ coils because they use a softer 240lb spring rate which flex way better.
Old April 8th, 2009, 03:05 PM   #92
deathbypsi
Brian R.
deathbypsi's Avatar
Here is another view on how good it flexes now with all my new springs. This hole had to of been about 35-38 inches deep because it swallowed my 33" tire and the suspension drooped pretty good into it.The other three tires were still sitting on the ground.
Last weekend I went wheelin with some guys from NWOC club and we hit some Knarly obsticles that a few of the straight axle Jeeps had trouble dealing with and my truck didnt. I was on 3 wheels more four that day! So far I am very happy with my TTB setup. Once I get my locker in and clearance my axle shafts where the U-joints are I can go to a longer front shock and gain another few inches of travel, then I cant see any reason to ever ditch the TTB.
Old April 9th, 2009, 09:46 PM   #93
Jdc215
Jdc215's Avatar
how much total lift do you have and what size are your tires?
Old April 9th, 2009, 10:00 PM   #94
deathbypsi
Brian R.
deathbypsi's Avatar
Tires are 33x12.50
I have 4" leafs with 2" shackles and the front has 3" drop brackets 4" coils.
Old April 10th, 2009, 10:12 PM   #95
lotusexige
lotusexige's Avatar
how bad does it rub the radious arms? i have heard that can be an issue with those.
lotusexige is offline   Reply With Quote
Old April 11th, 2009, 01:22 AM   #96
deathbypsi
Brian R.
deathbypsi's Avatar
Doesnt.
They are James Duff long travel arms.
Old April 27th, 2009, 03:56 PM   #97
deathbypsi
Brian R.
deathbypsi's Avatar
Finally got the truck sitting level with some 2" XJ coil spacers. Looks so much better to me.Fixed my camber also.
Here is the stock iso pad in my hand and the 2" on the truck already.
Now I just gotta clean it up a tad for BroncoRama!
Old April 27th, 2009, 05:48 PM   #98
88mudder
In the band!
looks good cant wait to see it at Broncorama
Old May 18th, 2009, 08:05 PM   #99
deathbypsi
Brian R.
deathbypsi's Avatar
Got my new XRC8 from IronmanOffroad the other day,nice winch! I also picked up some Daystar lights thru Jegs for 25.00 each.These lights are as bright as my 130w ProComps on my Ranger but they are only 55w.
Old May 19th, 2009, 11:35 AM   #100
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
Great build. Miss my old B2 even more!
SlayerXJ is offline   Reply With Quote
Page generated in 0.35250 seconds with 83 queries
