95 bronco not right - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 31st, 2008, 01:21 AM   #1
masterbeatty
masterbeatty's Avatar
Default 95 bronco not right
well after a new fuel pump, tune up and some good cleaning i took the truck out for a ride today and it will not hold a shift out past about 3 grand. if i shift it manualy it does fine but if i try and let the trans work it just shifts early. any ideas? tps maby?
Old December 31st, 2008, 07:38 AM   #2
booblinker
Sore and Tired 24/7
booblinker's Avatar
Does it still have normal amount of power, just doesn't shift?
Old December 31st, 2008, 06:09 PM   #3
masterbeatty
o yea runs real well.
Old January 1st, 2009, 10:24 AM   #4
masterbeatty
well lastnite it pulled about 4 grand and shifted but then would not do it again.
Old January 2nd, 2009, 09:33 AM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
What trans, I know those ford trans's had lots of electrical problems, check out fullsizebronco.Com, there is a shit ton of people there that have had trans problems.
Old January 2nd, 2009, 10:31 PM   #6
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
yeah, go to fullsizebronco.com, i'm a member on there, a lot of guys with ton's of bronco knowledge. if it's the e4od might be something in wiring, not telling it to shift right, if it's AOD, might need to adjust cable.
big_ol_bronco78 is offline   Reply With Quote
Old January 3rd, 2009, 01:02 AM   #7
masterbeatty
im on there to. yea i searched around. its an e4od im guna take it and pull codes and see what that gives me.
Old January 3rd, 2009, 01:21 AM   #8
big_ol_bronco78
Psalm 40:2
thats a good way to start. sounds like maybe a sensor or something, something not reading RPM's correctly
Old January 5th, 2009, 08:15 AM   #9
masterbeatty
well now it runs fine until about 4200 and it drops. it wont hold any gear out. i put an air intake on it and i went out and blew the rear driveshaft up so ill have to wait to see if that helps at all until i fix the shaft
Page generated in 0.23434 seconds with 50 queries
