2003 F250 Front end Clunk When Braking only - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 30th, 2008, 10:06 PM   #1
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Send a message via AIM to NoShow Send a message via Yahoo to NoShow
Default 2003 F250 Front end Clunk When Braking only
I have a 2003 F250 that has started to clunk under braking. Feels like it is coming from right under my foot on drivers side. Any one ever come across this...
NoShow is offline   Reply With Quote
Old January 5th, 2009, 12:31 PM   #2
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Been hearing it is probably sway bar bushings and links... Any one else have this issue??
Old January 5th, 2009, 12:52 PM   #3
Bones
Bones's Avatar
had to replace em on my 99
easy and cheap to do
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old January 5th, 2009, 01:22 PM   #4
bj house
bj house's Avatar
Yeah mine pops and clunks a little when unloading side to side at low speed. Feels like it is right under my feet. Thought that it might be a spring bushing but sounds like Bones may have diagnosed it better.
Does yours pull or pulse when braking as well? The lower pins on my calipers were rust and frozen when I pulled it apart a few months ago.
Old January 5th, 2009, 01:54 PM   #5
Bones
Bones's Avatar
well, when the sway bar bushings go bad, it will feel like there is a midget under there hammering on the floor.
My truck still has a cluck under the drivers seat, and I think it is the track bar bushing. I'm hoping not to have to touch that one until it is warm out, but it might be a spring bushing... it's hard to tell
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old January 15th, 2009, 11:08 PM   #6
gmotox
gmotox's Avatar
sounds like track bar or sway bar bushings, if you change the sway bar end links make sure to change the ones on the sway bar to frame also. it is common on the Fords!
Old January 22nd, 2009, 08:43 PM   #7
kiddd2
kiddd2's Avatar
the sway bar bushing are the problem..they go out all the time on those trucks
kiddd2 is offline   Reply With Quote
Old March 4th, 2009, 02:59 PM   #8
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Anyone know of a poly bushing kit for these?
Old March 4th, 2009, 03:07 PM   #9
bj house
bj house's Avatar
http://www.carpartswholesale.com/par...k_bar_kit.html
Old March 5th, 2009, 09:37 AM   #10
NoShow
Mmmmm Beeeer...
NoShow's Avatar
Thanks for the link, will check that out..
Old March 5th, 2009, 09:40 AM   #11
butters
It curves to the left...
butters's Avatar
just did a set for the same concern on an 03 super duty, links and bushings
took care of the problem
butters is offline   Reply With Quote
Old March 16th, 2009, 05:32 PM   #12
7.3X
Fullsize support vehicle
7.3X's Avatar
Got two excursions and both needed swaybar bushings. Very common prob.
7.3X is offline   Reply With Quote
Page generated in 0.29277 seconds with 59 queries
