ford 10.25 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 29th, 2008, 11:20 PM   #1
mudsliggin351
mudsliggin351's Avatar
Question ford 10.25
Im looking at a 1989 ford f250 for sale and i am wondering the 10.25 rear end anygood for offroading/daily driver?
mudsliggin351 is offline   Reply With Quote
Old December 30th, 2008, 08:16 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Well, it's a 3/4-ton truck axle, so that should tell you something.
Old December 30th, 2008, 01:38 PM   #3
mudsliggin351
Thnx do you know if they are a floating axle or not?
Old December 30th, 2008, 03:18 PM   #4
creepyjon
3/4 are normally semi floating, 1 tons are full floating. BUT a 3/4 ton can have a hd suspension upgrade from the factory and use 1 ton axles. Both of my f250's had the 1 ton axles under them.
creepyjon is offline   Reply With Quote
Old December 30th, 2008, 05:08 PM   #5
mudsliggin351
What is a semi-floating axle? Does it have it so you cant take the axle out of the hub or no?
Old December 30th, 2008, 10:26 PM   #6
Take a picture of it and post it. If it's not a full floating axle, they aren't hard to find if it concerns you.
Last edited by feva4u; December 30th, 2008 at 10:30 PM. Reason: didn't realize in tech section
Old December 30th, 2008, 11:46 PM   #7
mudsliggin351
I do not have the truck yet and im wondering because the guy doen't know if it is or not.
Old December 31st, 2008, 12:08 AM   #8
mudsliggin351
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Found some info that has to do with the 10.25.
It is a full floating axle.
Old January 1st, 2009, 11:25 AM   #9
Ggg
10.25 can be a FF axle, there was a SF version with 7 lug bp used in the HD F150 of the late 90's. The HD 10.25 was used in 3/4 and SRW 1 tons. it is comparable to a Dana 70 for strength, it will have drum brakes, and std. 8 on 6.5 bp. Plenty of gears and lockers/posi's available.
Ggg is offline   Reply With Quote
Old January 2nd, 2009, 09:33 PM   #10
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
it's a great axle to upgrade too, will add a lot of weight, but it'll be hard to break. also, make sure you measure it up, i've heard some people have a tough time getting them to line up and fit in their 1/2 tons, but unsure of what years.
big_ol_bronco78 is offline   Reply With Quote
Page generated in 0.19569 seconds with 53 queries
