explorer column ignition problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 28th, 2008, 11:19 PM   #1
kevinr839
kevinr839's Avatar
Default explorer column ignition problem
A friend of mine has a 03 explorer and the rod conecting the ignition cylinder to the ignition switch is broken or un hooked somehow. Switch is good, lock cylinder is good it is whatever conects the two that is broke. Anybody have this happen and how hard is it to change just that piece? It seems to be inside the column.
kevinr839 is offline   Reply With Quote
Old December 29th, 2008, 09:13 PM   #2
creepyjon
It would be easier to change the whole steering column. Modern cars use some pretty nasty anti theft stuff in them. It would be a major project to even try to get it apart, the column is only held on with about 4-6 bolts tops, and maybe 2-3 electrical connectors.
creepyjon is offline   Reply With Quote
Old December 30th, 2008, 09:21 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
There's a little "horseshoe" looking piece that comes out of the gear behind the ignition cylinder and connects to the rod on top of the column and they break quite often. You have to pull the column apart (pull ignition cylinder, air bag, steerign wheel, column pivots, etc) to replace it. Takes 1-2 hours to do it.
Old December 30th, 2008, 12:26 PM   #4
Troll53
Lurker under the bridge
Troll53's Avatar
Send a message via MSN to Troll53
Here is an exploded view, there is no linkage anymore the cylinder mounts opposite of the switch.
Troll53 is offline   Reply With Quote
Old December 30th, 2008, 02:24 PM   #5
kevinr839
kevinr839's Avatar
I got the peices from the dealer but was wondering what the easy way to replace it is and if there is anything to really watch for. I know the airbag stuff, but how about the tilt mechanism.
Page generated in 0.19691 seconds with 38 queries
