extending radius arm question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 28th, 2008, 07:59 PM   #1
creepyjon
Default extending radius arm question
Hey I've got a crazy idea, so here it goes. A few companies sell extended radius arms for ford axles. Why can't you take the arms that are under it, and use the bolt threads on it to screw into a extender bar. Obviously the arm will have to be very beefy, 2x2 square bar .250 thick maybe?
Or would it be better just to weld strait to it? I can fabricate up stuff, so is it worth a shot, or am I just plain nuts? The reason I want to do this is I will be lifting my 79 f150 up at least 9 inches to clear some big tires.
creepyjon is offline   Reply With Quote
Old December 28th, 2008, 09:00 PM   #2
F150hybred
Well versed in TTB
F150hybred's Avatar
Extending radius arms arms been done more ways than there are to make chicken soup. What you are talking about has been done.. but isn't the strongest way to make them longer. Best way... if your gonna do it yourself... is to peel open the wrapped metal around the bushing stud and have longer ones made. Then you can weld them in place as the factory did.
Myself, I'm looking into a way to make a "modified" four link that would work in place of the radius arms. Way I see it, if both upper and lower links are identical in length or close to identical, your caster change would be as minimal as possible and would make for some wild suspension articulation while also being as durable as possible too. Not to mention, I don't think I have seen anybody do it THAT way yet.
It''s still in the works... and could quite possibly be a reality sometime soon.
F150hybred is offline   Reply With Quote
Old December 28th, 2008, 09:04 PM   #3
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
I know a buddy who runs a '79 Ford pickup and we have done alot of suspension work to it including lengthening the radius arms. We cut the ends off the arms and sleeved them with a heavy wall rectangle tubing and steel plating. After that we welded on some big Jonny Joints to the end and made new frame mounts. The arms are 16 inches longer and flex like mad even with the stiff six inch lift springs he bought years ago. You have to keep an eye on trac bar bushings unless you run poly or the steering gets twitchy.
Old December 28th, 2008, 09:10 PM   #4
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Mine on my bronco were 47"s long and had 1-1/4" heims on the end of them. I cut them 6in behind the C-cup on the arm and interlocked some 2"-1/4"wall dom on them. Worked great and flexed like mad. Best set up i had it.
Old December 28th, 2008, 10:36 PM   #5
creepyjon
Ok nice to know I'm not that crazy then. Anyone have pics of their radius arms after they customized them?
Old December 28th, 2008, 10:38 PM   #6
88mudder
In the band!
x2 id like to see some closeup pics because ive been thinking of extending my stockers.
Old December 28th, 2008, 10:42 PM   #7
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
http://www.rmftc.com/howtos/extended...adiusarms.html
http://www.tomsbroncoparts.com/produ...gory=5&id=1098
The second one is basically what mine will probably end up looking like. Since my truck is a little tall I was going to make them bend to run along the frame and tuck up a little bit to try to keep the pinion angle from being too bad.
Grunto is offline   Reply With Quote
Old December 29th, 2008, 11:12 PM   #8
Fullsize4life
Kicking Cancers ASS
Look in the Rig builds section here on greatlakes. Under 78 Bronco is mine. Im sure there are some pics on there.
Old January 2nd, 2009, 11:28 PM   #9
alboy79
Where's your loyalty lie?
alboy79's Avatar
Location: Comstock Park, Michigan or 49321 for shipping
on mine i cut off just the threaded end of the arm and had 13" of 1.25" solid round stock welded on the end then had the threaded end welded back on the solid stock. worked good under my 79 bronco but not fantastic. i had no problems with bending or breaking but i didnt get the flex i wanted. a flex joint of some sorts would have been better. now i have the arms that Fullsize4life had on his bronco. im going to use them with Johnnny Joints on the ends and see what happens.
alboy79 is offline   Reply With Quote
Old January 4th, 2009, 07:11 PM   #10
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
STEP 1 =
STEP 2 =
No pics of STEP 3
Page generated in 0.30849 seconds with 53 queries
