1996 400 sportsman wont go in 4x4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2008, 08:53 PM   #1
jeffandjess4806
In the garage
jeffandjess4806's Avatar
Default 1996 400 sportsman wont go in 4x4
I am not sure why...any tips for me to check b4 i send it to the shop?
jeffandjess4806 is offline   Reply With Quote
Old December 27th, 2008, 09:13 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well you've hit on something I know all to well. my buddy had a 400 that would do what yours is every year about hunting season. anyways if you are not seeing any engagement then you have to see if the shaft going to the wheels are turning. they normally are. the fact yours has magnetic hubs and reaction discs is the normal problem. they thrust washers that ride againest the inside of the hubs wear and so do the face of the magnets with is the bottom half of the strut. I have had to replace them before for grooves worn in them by the reaction disc. the other plroblem is the hub clutch. it rides on the spindle inside the hub and is held in with guts of the hub assem. if by chance its worn so bad as to open up the inside of the hub it will cause slipage at the wheel. the biggest thing people don't realize is the hubs have to disengage then re engage when switching from forward to reverse. if you under power and stuck you will almost always smoke a hubs clutch. I suggest jacking up the machine and see which wheels turn when the gas is applied. make sure the axles turn to the front hubs and then see if you can hold tire and if it happens to move on one side and not the other. if it picks up the other side your good. the other thing to do is use a test light to make sure you have power to the magnets in the struts. I would do that first.
Yetti
Old December 27th, 2008, 09:13 PM   #3
xj97sport
atv rider
xj97sport's Avatar
ya what yetti said
Old December 27th, 2008, 09:29 PM   #4
jeffandjess4806
In the garage
PM sent yetti
Old January 1st, 2009, 08:06 PM   #5
Yetti
Yetti's Avatar
Any luck yet?
Yetti
Old January 2nd, 2009, 01:06 AM   #6
jeepguy74
jeepguy74's Avatar
usually on those it is the switch that sits in the shifter it will go bad
does the neutral light stay on???
does the light on the bar come on?
Page generated in 0.18211 seconds with 41 queries
