altenator power - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2008, 07:55 AM   #1
acenho
Default altenator power
I have a 2003 Superduty that I run front and rear plows on. It was getting to the point when it was cold outside that the radio would shut off and the lights would dim when the plows were raising. After a while the engine actually shut off once. I replaced my battery with a new yellow top optima battery, but the lights still dim. Is there a high amp low rpm altenator available? most operation is at low rpm,
Thanks
acenho is offline   Reply With Quote
Old December 27th, 2008, 08:28 AM   #2
Yota Bill
http://www.mean-green.com/products/alternator.html
never used one personally though
Old December 27th, 2008, 08:53 AM   #3
booblinker
Sore and Tired 24/7
booblinker's Avatar
Put a smaller pulley on the alternator, that will help.
Old December 27th, 2008, 12:26 PM   #4
frdboy
frdboy's Avatar
What motor?
Best case would be a second battery.
You can get better alternators but they are $$$.
If you could find a smaller pulley it would help.
Old December 27th, 2008, 12:30 PM   #5
acenho
v-10
Old December 27th, 2008, 12:58 PM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
Originally Posted by frdboy View Post
What motor?
Yea for sure, I thought he said he had 2 batteries for some reason, you definatly need 2 batteries for running front and rear plows.
Old December 27th, 2008, 01:01 PM   #7
frdboy
frdboy's Avatar
You have a 110 amp. alternator, you could get one for a van or excursion. those are 130 amp. The mounting on the bottom looks to be the same but the top is different. Not sure if it would work or not plus you are only gaining 20 amps. May not be worth it.
I would look at putting a second battery in first.
Old December 28th, 2008, 08:36 AM   #8
acenho
I have been running 2 plows on this truck for 5 seasons, only ever had 1 battery, the stock battery, this is the first time the drain shut the truck down, I dont believe 2 batteries make a difference, I had two batteries on my previous truck and it had similar problems. this rig is plowing driveway to driveway, without enough amp output I dont think 10 batteries would help as they are not getting enough time to charge after constant draw. But I could be wrong I am not an automotive electrician, but I do know I rarely get over 2000 rpms so there is not much output,
Old December 28th, 2008, 10:42 AM   #9
frdboy
frdboy's Avatar
Yeah, if the alternator isn't keeping up two batteries will only help a little.
Maybe you should have your alternator checked for output, it could be on its way out.
Old December 28th, 2008, 05:33 PM   #10
acenho
tell me how, i do have a multi meter and it does put out 14.1+ volts but not sure how to check amperage output. to test the volts I just checked at the battery
Old December 31st, 2008, 02:39 PM   #11
insaneoffroader
insaneoffroader's Avatar
try this guy out he seems to be an electical guru. i believe he is over by Lansing.
http://rjminjectiontech.com/?p=6
insaneoffroader is offline   Reply With Quote
Page generated in 0.26331 seconds with 56 queries
