D44 Wedge Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 26th, 2008, 01:09 AM   #1
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
Default D44 Wedge Question
So I am starting to get to the point where I am making plans to either 3-link my front axle or make some new extended arms to eliminate my mounts that hang so low under my frame.
Question part: On 78 and 79 Ford HP44's, are the wedges cast? Could a link mount be welded to the wedges if I'd cut them?
This is basically what I am looking into, the red line shows the cut I'd make then a mount would be welded there.
Grunto is offline   Reply With Quote
Old December 26th, 2008, 06:27 PM   #2
low900rr
low900rr's Avatar
you should be able to see if the wedges are welded on or not. If they are then cut them off and weld to the tubes.
low900rr is offline   Reply With Quote
Old December 26th, 2008, 07:01 PM   #3
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
78 & 79 are part of the knuckle. You cannot cut them were you want to. If you do it would then be open to your axleshaft. You should be able to weld to them. If you are a good welder.
Old December 26th, 2008, 10:37 PM   #4
lgottler
lgottler's Avatar
When I cut mine apart, I was surprised how little material there was there. In my opinion, cutting and welding should be avoided, I would take another route. What about extended, wristed radius arms? Extend 'em both and wrist/pin the other....
lgottler is offline   Reply With Quote
Old July 29th, 2009, 11:46 PM   #5
Grunto
Grunto's Avatar
Updating this with another question...
What vehicle and years should I look for if I were looking for a HP44 with the wedges welded on originally instead of being part of the axle tubes? It would have to be the same wms-wms measurement.
Old July 29th, 2009, 11:55 PM   #6
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
77-79 F-150 had both options I believe. Just have to look at them to determine which style. Mine had weld-on wedges and it was from a '78 or '79...can't remember which exactly.
*2007 Rubicon
*2006 Duramax
Old August 2nd, 2009, 09:27 PM   #7
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
76-77 had the weld on wedges. 78-79 were cast. If you find a 76-77 to use you will be way better off.
Old August 2nd, 2009, 10:33 PM   #8
muddywater
Stacks bring the awesome
muddywater's Avatar
Send a message via AIM to muddywater Send a message via Yahoo to muddywater
76-77 is what i have under my truck and i cut the wedges off to weld leaf spring perches on it. good luck.
muddywater is offline   Reply With Quote
Old August 2nd, 2009, 10:35 PM   #9
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
good info to know for axle swaps. 76-77 is the axle to get to save troubles. Thanks guys.
84mudder is offline   Reply With Quote
Old August 3rd, 2009, 06:12 PM   #10
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
78-79s arnt bad just build a good set of arms and they work out good as well but i guess its all about preference too...
Page generated in 1.00915 seconds with 53 queries
