Furnace Issues - Looking for recomendation - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2008, 11:25 PM   #1
techman
Default Furnace Issues - Looking for recomendation
Last week, my furnace started acting up by randomly not igniting, traced it down to the controller not enabling the gas (relay was failing), so replaced the controller and the furnace started working again.
Tonight the combustion blower stopped working, 4 mfd run cap decided to fail, I pulled a 7.5 mfd from another motor, wired it up, and we have heat for tonight.
This furnace is old and tired, (16 years old), looking to replace it, this furnace is York, Natural Gas, mid/high eff, 100,000 BTU.
What is a good brand? What is a good price installed?
techman is offline   Reply With Quote
Old December 21st, 2008, 11:46 PM   #2
JEFF
Hold my beer!!
JEFF's Avatar
Call around (if you can hold out that long) get some estamates put togather, then make them work aginst each other so you get a better price. I did this 2 years ago by calling the company I wanted to do it, but were out of my price range and telling them " thanks for the estamate, but Im gonna have this guy do it" They ended up matching his price.
I got a Carrier Mid eff unsure on the BTU's Cost $2500 parts and labor
JEFF is offline   Reply With Quote
Old December 22nd, 2008, 04:33 PM   #3
shawn
Resident HVAC/R Jambi
shawn's Avatar
As far as brands, I have stuck to either Comfort Maker, Goodman, ArcoAire, Rheem, those have all been great units and the prices are very reasonable.
As far as what it would cost you, that is all relevant mostly to what all needs to be done to install it in your hosue. And if you are putting AC in also.
FYI, York just came out with a new High E Furnace, something like 99%!! I bet it's expensive though.
Old December 22nd, 2008, 05:19 PM   #4
Porter
Porter's Avatar
Default Hmmmmm
PM Harley
Porter is offline   Reply With Quote
Old December 22nd, 2008, 05:41 PM   #5
Bow_Extreme
Bow_Extreme's Avatar
I put a Goodman furnace is in my house. I installed it myself and it's worked great for the last 3 years. I think I had around 1300 into the job when I was done. It's around 70,000 BTU range. The only reason I didn't upgrade to 100,000 was because I didn't want to change the vents to 3" PVC. I was surprised, I didn't expect goodman to hold up but it has held up well.
Bow_Extreme is offline   Reply With Quote
Old December 22nd, 2008, 07:26 PM   #6
brewchief
I work for a Lennox dealer so I am biased towards them, regardless of the brand if it's not installed properly it will not last, I'd rather have a perfectly installed goodman then a hacked in Lennox or Carrier. Most of your brands will have multiple lines, builders model, mid grade, upper grade, premium, and sometimes a super duper premium. Make sure you know what your getting. I would suggest a two stage model, you will get longer run times but at a lower firing rate, running longer at a lower rate will keep the temp in the house more even thus more comfortable. I recommend a good media filter for every furnace, you wouldn't drive your truck with a piece of crap air filter in it, why would you run your furnace with one? If you want to be able to run the blower a lot for air filtration, humidification, or just want the air circulation then look into a variable speed blower, it uses a more efficient DC motor for the blower.
Price wise you could be under 2k for a basic unit with no extras or over 5k for top of the line with all the goodies, my suggestion would be a two stage unit with an air cleaner, pretty much in the middle price wise.
Any questions shoot me a PM, and no I don't want a side job.
Brewchief
brewchief is offline   Reply With Quote
Old December 22nd, 2008, 07:45 PM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
PM Curt1656.
BTW, I bought a 96,000 96% efficiency furnace online at www.alpinehomeair.com
@clarkstoncracker
Old December 22nd, 2008, 07:48 PM   #8
clarkstoncracker
lol
clarkstoncracker's Avatar
Curt1656 FTW.
And his big hands are very soft
Old December 22nd, 2008, 07:50 PM   #9
shawn
shawn's Avatar
Curt1656 FTW.
werd
Old December 22nd, 2008, 08:02 PM   #10
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
Curt1656 is a raging homosexual. BUT he is VERY good with HVAC stuff. Even if he talks to you for excessive amounts of time about running "new pipe" he will do you well. No pun intended.
Old December 22nd, 2008, 11:10 PM   #11
techman
Thanks everyone for all the input. I talked to Curt earlier, great guy, very knowledgeable, I have some options I need to think over.
Old December 23rd, 2008, 07:44 AM   #12
curt1656
Praise the lowered
curt1656's Avatar
I didn't have homo tendencies until I met Hacksaw. He sucked me into it.
Page generated in 0.26732 seconds with 58 queries
