Sloppy Shift Lever in '02 F350 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2008, 04:38 PM   #1
rentalrider
rentalrider's Avatar
Default Sloppy Shift Lever in '02 F350
Hello all, could use some advice. I have an '02 F350 with the 7.3. Auto w/ overdrive. The tranny seems to function perfectly, but the shifter lever on tree is sloppy. Sometimes difficult to find correct position and since it's my personal plow truck, becoming a nuisance real quick in this weather. Is this an issue with tranny? Linkage? Inside the tree? Easy fix? And lastly, this is my DD, so wondering if this is likely to leave me or my wife stranded somewhere? (live pretty deep into country). Would appreciate any advice you can offer on this... Thanks in advance. Oh yeah, pro'ly not gonna matter but it's got 120k on odo.
Old December 21st, 2008, 06:20 PM   #2
masterbeatty
masterbeatty's Avatar
its up under the colum/dash. here is a screw that works loose over time, my dads trucks have done it and he tightens them and they come loose again. not hard to fix just kinda time consuming. ill ask him exactly where it is. but it wont leave ya stranded.
Old December 21st, 2008, 08:28 PM   #3
rentalrider
Fantastic! I'll wait to hear back, but that sounds like the best possible scenario. Just pm me when you hear, and thanks!
Old December 21st, 2008, 10:24 PM   #4
bronco4-play
Do it like you mean it
bronco4-play's Avatar
I'd like to know more about this fix also, as I have the same truck with the same issue.
bronco4-play is offline   Reply With Quote
Old December 23rd, 2008, 08:55 PM   #5
smasheromalley
smasheromalley's Avatar
Interesting, I been thinking the shifter on my '00 F350 was a little sloppy lately too...
Old December 24th, 2008, 10:44 AM   #6
kevinr839
kevinr839's Avatar
Default bushings
We have a fleet of f-250's where I work and we deal with this alot. There are a couple problems that happen with the shifters. The first is the Bushings for the shift tube wear out, all you have to do is drop the column (4 bolts) and you can change them fairly easy. Another thing we have een is the screws at the bottom of the shift tube on the column where the cable hooks up become loose and or fail out, you can reach those from under the dash without dropping the column. We have also had a few crack and break the shift tubes, usually after they have been loose for a while and the drivers try slamming them into park. It can leave you stranded if the tube breaks or both screws fall out of the shift tube/ cable conection.
kevinr839 is offline   Reply With Quote
Old December 24th, 2008, 10:46 AM   #7
kevinr839
kevinr839's Avatar
Also another common problem we have is the overdrive button wiring wearing out on the column and the button not working or blowing the fuse for the gauges.
Old December 24th, 2008, 01:12 PM   #8
wdkdusters
wdkdusters's Avatar
ive seen this the screws come lose take out and put lock tight on them thay should be fine
wdkdusters is offline   Reply With Quote
Old December 26th, 2008, 08:06 PM   #9
bronco4-play
Thanks for the tips.
Old December 27th, 2008, 04:31 PM   #10
masterbeatty
yea that about sums it up. i just got to talk to him about it. im actually replaceing the colum in my bronco in a few mins
Old January 22nd, 2009, 12:04 AM   #11
rentalrider
Fixed!! The 2 screws (star head) near base of column under dash (just above steering shaft) worked loose. Tightening fixed it. Thanks for all the help!
Page generated in 0.29803 seconds with 56 queries
