Tube Bender Plans ? ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2008, 02:30 PM   #1
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Default Tube Bender Plans ? ?
What do you guys think of this bender. Plans are only $17 and i have acess to to every thing to make. Just curious to what every one thinks of it. Id be doing the Air/Hyd one
http://www.gottrikes.com/Tube_Bender.htm
Old December 21st, 2008, 03:44 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
what dies does it use?
Old December 21st, 2008, 04:41 PM   #3
Tab
Tab's Avatar
Those plans have been around awhile. Ironman has that setup and it uses (at least his does) pro tool dies. The actual bender frames are not that expensive, its the dies that you will still need to buy. They range from 180-450 for each size. But the bender does work decent.
Old December 21st, 2008, 05:05 PM   #4
1badzuk
1badzuk's Avatar
i didnt like the way he "reverse engineered " from pro tools dies did mine on a mill triple shecked b4 and after and things were just exta sloppy in the end i wish i would have bought a pro tools one already set up.
1badzuk is offline   Reply With Quote
Old December 21st, 2008, 05:49 PM   #5
bbaXJ
Yooper In Training
bbaXJ's Avatar
My ProTools is a lot sloppier than I'd like too, so that's not really the solution. I've known people to have great luck with that style bender.....I wouldn't mind having one, but my ProTools does the job just fine too.
Old December 21st, 2008, 07:44 PM   #6
tom77cj5
tom77cj5's Avatar
i just put one in the misc for sale section
with steel prices so high still i would be willing to bet it would be cheaper to buy one new or used rather than build one unless you had the steel already
Old December 21st, 2008, 08:44 PM   #7
lgottler
lgottler's Avatar
I built four of those Trikes ones. Mine is still in my garage without a die. It went together OK, but I would change a few things. Head over to Pirate4x4 and search for this bender, check out the mods and maybe tweak a few things when you build it.
I used the air/hydraulic one, but my compressor at home is too small to run it (small pancake).
lgottler is offline   Reply With Quote
Old December 21st, 2008, 08:47 PM   #8
1badzuk
1badzuk's Avatar
another thing to remeber is to have ram on hand when building so you can chage holes in arms as you go some rams vary
Old December 23rd, 2008, 06:45 PM   #9
Mud'N'Truck
So i have the plans now, and im now curious to what you guys would change, add, remove or any thing.
Old January 1st, 2009, 07:30 AM   #10
nite crawler
Scout II
nite crawler's Avatar
Why spend any money,,,,when Old Trampoling part's will be layin on the side of the road this spring????? Pree-bent 90,45&20s just waitin to be made into ''TUBE-ART''
Remember ''DRIT,CHEAP,FUN!!!!
nite crawler is offline   Reply With Quote
Old January 1st, 2009, 01:17 PM   #11
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
ummm....seriously dude? Keep your ''DRIT,CHEAP,FUN!!!!" away from me please.
Old February 3rd, 2009, 02:01 AM   #12
1badzuk
1badzuk's Avatar
hell yes just buy a NEW jd2 and be done i wish i would have but only buy NEW because they come with free shipping a degree wheel and ratchet parts!!!!!!!
Page generated in 0.28204 seconds with 59 queries
