Disconnect D30 to non disconnect shaft seal numbers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 20th, 2008, 08:07 PM   #1
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Default Disconnect D30 to non disconnect shaft seal numbers
Thanks, CC.
For future reference, the following axle seals will work in YJ disconnect housing with a TJ shaft in place of the original shaft:
Napa CN11771
Mazza's 40576S
National - 7757
Old December 24th, 2008, 01:07 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Also CR11343
Old May 5th, 2010, 06:51 PM   #3
bomberdon
I have a D30 from a 89 YJ with disconnect. Bought whole D30 from a 95 XJ. Do the seals go inside by the diff. or outside the CAD where it's in stock location? D30 in a 86 S-10 with leaf spring set up. Going to a long arm coil set up next winter.
bomberdon is offline   Reply With Quote
Old January 16th, 2013, 07:46 PM   #4
pitbull2332
pitbull2332's Avatar
Napa seal has a new part number. 11782
pitbull2332 is offline   Reply With Quote
Page generated in 0.20312 seconds with 35 queries
