Yamaha Exciter 2 SX 1993 sale pending
This is the last yr yamaha made the exciter ! This modle is a rare one as they added all the fatory performance mods and labled it the SX .
Comes from the factory with reported cylinders to boost performance, larger flat slide carbs, and higher compression than standard exciters,
suspention wise they added adjustable front suspention shocks, widened the front stance and tipped the front shocks forward a little. rear suspention used coilover adjustable shocks on both front and rear of the track so you can adjust it to your likings.
the engine is a liquid cooled 570 with a stock exhaust. track is studed , heated handle grips with hi/lo off switch, heated thum warmer . skies have skines on them, with newer carbides. the sled is a blast to ride and has a very good power to weight ratio !! sled is light for deep snow riding with more than enough power to play with friends on the straights !! 1000.00
