how to fit CJ/YJ doors on a TJ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2008, 07:51 PM   #1
muddy maki
Its tough out there.
muddy maki's Avatar
Send a message via AIM to muddy maki
Default how to fit CJ/YJ doors on a TJ
Ending the controversy CJ/YJ doors on a TJ
For years it has been said that CJ/YJ doors will not fit a TJ because the windshield angel is different or yada yada yada. Then JP mag had an article on TJ doors and tops on an YJ witch sparked peoples interest but never really resolved the myth. Well after finding some CJ doors for a decent price for less than I would have spent on an ok set of tj doors. I decided to look further into this myth. I knew CJ/YJ doors would fit the door opening but knew there would be two major hurdles. The CJ/YJ doors use a pin style striker and TJ’s use a loop style striker, and I knew CJ/YJ window cranks may have clearance issues with the TJ dash. This all turned out to be true, and as I stood looking at the doors on my jeep trying to decide if I should purchases them I came up with a plan to over come these problems. Three weeks later I picked the doors up and began putting this myth to bed.
This is what I found and how I got around it.
My plan to overcome the window crank problem was simple and sweet. Remove the dash speakers and covers (being as I have no dash speakers anyway) it seemed like an easy fix. It worked like a charm allowing just enough room to roll down the window at the Wendy’s drive through on those cold winter nights.
My next plan of action was to address the striker problem. It turns out that the TJ striker is actually mounted to the tub about 1” lower than the CJ/YJ. My plan was to mount the striker in the upper mounting hole for the TJ loop strikers and go from there.
It turned out great only the left (driver) side needed to be reamed just a little bit; the right (passenger) side needed no modifications.
This is the retainer that your factory tj strikers bolt too it must be removed. It’s loosely held in place by a metal tab pictured below.
The metal tab you have to bend out of the way.
CJ/YJ Striker mounted notice the spacers. It took allot of them I reused all the shims from my used CJ/YJ strikers and added washers to make up the difference.
On the right side I had a little hiccup the factory had not installed the plastic on the A pillar (windshield frame) very well it was a 1/2” lower than the hard top surface. I had to unscrew it move it up to make it flush and drill new holes for my screws so the door would close correctly.
After moving it up.
After the hinges were all adjusted. Notice I had to move the lower tub mounting hinge. If you ever have to remove or adjust one of these if it won’t budge be sure to heat it from inside. I busted both of my T 40 bits on this one hinge.
The bottom door gap is tight! But it doesn’t appear to be rubbing and the door cannot be moved up any more.
The top would be nice to have a bit higher but I can’t move the door any higher or it hits the hard top in the front.
Window crank worked great.
Overall fit after all done. The only thing that gives away this is a CJ/YJ door is the window pillar and the reversed handle.
I did the right side first and it took me just a bit over an hour. The left side took me only half an hour.
muddy maki is offline   Reply With Quote
Old December 15th, 2008, 08:00 PM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
damn that turned out great! Glad to see everything lined up ok and worked for you!
Now lock it up!
Old December 15th, 2008, 08:10 PM   #3
muddy maki
muddy maki's Avatar
Now lock it up!
thanks for reminding me i need to go lock the tailgate. time for a smoke
Old December 15th, 2008, 09:09 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
haha, I'm going to make a sneak appearance late tonight to ensure its fully locked. We shall see if it passes the test.
Old December 15th, 2008, 09:18 PM   #5
muddy maki
muddy maki's Avatar
Old March 11th, 2009, 09:52 PM   #6
jakesjeep01
Fukc it
jakesjeep01's Avatar
Default The opposite...
so will TJ doors fit a YJ?
jakesjeep01 is offline   Reply With Quote
Old March 23rd, 2009, 10:49 AM   #7
muddy maki
muddy maki's Avatar
as i understand it yes. but mods will be nessasary. probably easier than yj to tj i will bet.
Old March 23rd, 2009, 10:55 AM   #8
1badzuk
1badzuk's Avatar
soo spend good money on a tj to rip interior appart and not have them fit just right to save money on doors?
hats off to ya for figuring it out it looks good but i just dont get the method to the madness?
1badzuk is offline   Reply With Quote
Old March 23rd, 2009, 11:05 AM   #9
biohazardbill
The Biohazards
biohazardbill's Avatar
Full YJ doors are cheaper than full TJ doors.. why not sell TJ doors if you have em and pick up YJ ones... easier to install and u pocket some dough
biohazardbill is offline   Reply With Quote
Old March 23rd, 2009, 02:54 PM   #10
muddy maki
muddy maki's Avatar
im gona put power windowes in so i can put my speaker couvers back togeather. and sorry if i dont make enough money to buy TJ hard doors im not in my forties with a advanced degree and high paying job. i make $8 per hour and work 20 hours a week. get it now?
Old March 24th, 2009, 06:57 PM   #11
1badzuk
1badzuk's Avatar
sorry buddy no degree not in 40's and i make less per hour(layed off) just asking why didnt mean to offend or dump sand in yer e-gina
good job on doors
Page generated in 0.47947 seconds with 56 queries
