B2 rear DS upgrade? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2008, 05:45 PM   #1
deathbypsi
Brian R.
deathbypsi's Avatar
Default B2 rear DS upgrade?
I know I have seen it some place about a better rear driveshaft than this toothpick my 90 Bronco2 has in it stock.
Was it a Explorer shaft that would work in a B2 with a a4ld and a 7.5?
Old December 15th, 2008, 05:47 PM   #2
88mudder
In the band!
heavy duty shaft, you can buy them at any autoparts. Mine happens to be from Napa.
Old December 15th, 2008, 05:53 PM   #3
deathbypsi
Brian R.
deathbypsi's Avatar
Not lookin for parts with "new" price tags. Been laid off for a while so I am lookin for a budget option. I have junkyards all over down here.
Old December 15th, 2008, 07:05 PM   #4
88mudder
In the band!
Explorer shaft should work, i would say cut it to fit.
Old December 15th, 2008, 07:39 PM   #5
Jdc215
Jdc215's Avatar
according to cheap thrillsb2 an explorer front shaft will work as a Bronco II rear drive shaft so long as you get the right hardware to adapt to the flanges. he says thats what hes running and he beats on his rig hard and has some serious lift. should do you good. you may want to talk to him for exact details.
Jdc215 is offline   Reply With Quote
Old December 15th, 2008, 08:08 PM   #6
take the front output from a 1354, bolt it in place of the rear output on the 1350....
take the ujoint flange and install on the other side of the explorer shaft.
I cannot not recall exactly the measurements....but it should be close enough to work.
Old December 15th, 2008, 10:37 PM   #7
deathbypsi
Brian R.
deathbypsi's Avatar
Are we talkin first gen Exploders?
Thanx for the help!
Old December 15th, 2008, 10:38 PM   #8
91-94 yes
Old December 17th, 2008, 10:02 AM   #9
fsumotorhead
N8KVB
fsumotorhead's Avatar
91-94 yes
up to 96 should work, as ford used the 1354 in the electric variety til then.
jontboudrie(sp) has a 96 X in the partout forum, and he's in Monroe to boot
Page generated in 0.27205 seconds with 50 queries
