Why do you not see OX lockers more often? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 15th, 2008, 03:29 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default Why do you not see OX lockers more often?
I always liked the philosophy of an OX over an ARB.. just seems like it would be less maintenance.
Why do you not see them more often? Is it the price or are there other inherent problems with them IE weak? I know they seem to be quite a bit more expensive.
Old December 15th, 2008, 03:43 PM   #2
95geo
newbie
95geo's Avatar
the arb is by far the more reliable solution if installed and plumbed correctly.
the problem with the ox lockers is that the cable adjustment is super sensitive and they came out of adjustment very easily when the suspension cycled.
there is a reason arb's have been around as long as they have and none of the other styles of selectable lockers have stayed.
Old December 15th, 2008, 03:49 PM   #3
junk90xj
ALLPRO AUTO
junk90xj's Avatar
cables need adjusting quite often. cables rust up and seize easily in michigan.
i seen nothing but problems with the cables and alot of problems with them too.
http://www.apalansing.com/
Old December 15th, 2008, 03:50 PM   #4
jeepfreak81
81 inches of fun
I honestly figured it would be more that ARB pumps 10x the money into marketing
Old December 15th, 2008, 03:57 PM   #5
Bones
Bones's Avatar
i would agree with that
cable are a poor excuse. good cables are cheap and do not rust. I'm not talking about B and M cables...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 15th, 2008, 04:01 PM   #6
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
on the crawl winter run a few years ago the one Ox on the run had it's cable freeze and he couldn't lock his axle in.
Then again, my hub froze and I had to take it apart and put it back together to get it to lock in.
JohnnyJ is online now   Reply With Quote
Old December 15th, 2008, 08:19 PM   #7
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
the cable costs just as much as the ARB compressor, the lockers are comparable in price. I would opt for the ARB over the ox. The Ox cable must be readjusted everytime you remove the cover.
Old December 15th, 2008, 08:26 PM   #8
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
i asked a guy at a 4x4 shop in pheonix this question a few months ago. he told me a big reason none of those guys use is how hard it is to repair it on the trail. if you break a hose it is super easy to splice together compared to having to replace an entire cable. also you get onboard air when you do the airlockers.
Old December 15th, 2008, 08:56 PM   #9
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
What I don't understand is Jacob already has a OBA system
Old December 15th, 2008, 09:00 PM   #10
jeepfreak81
81 inches of fun
I'm dreaming anyway right now
We all know the YJ will never move again
Old December 15th, 2008, 09:03 PM   #11
brimy311
Smells like a Fork Liftis
brimy311's Avatar
1.) Hard to get adjusted correctly. The cables can easiliy get wrecked.
2.) They are as expensive as ARB's.
3.) There customer services is quite possibly the sh!ttest ever.
4.) They suck.
JcrOffroad.com
Like us on Faceook!
Old December 15th, 2008, 09:04 PM   #12
brimy311
brimy311's Avatar
You have a YJ?!?!
JcrOffroad.com
Like us on Faceook!
Old December 15th, 2008, 09:04 PM   #13
Jeepaholic
Jeepaholic's Avatar
I will come over next week and tow you around in the yj
One thing I have learned threw stupidity is one jeep is more than enough
Old December 15th, 2008, 09:10 PM   #14
alboy79
Where's your loyalty lie?
alboy79's Avatar
Location: Comstock Park, Michigan or 49321 for shipping
thats the truth. its the number one reason i wont buy anthing from them.
alboy79 is offline   Reply With Quote
Old December 15th, 2008, 09:36 PM   #15
jeepfreak81
81 inches of fun
You have a YJ?!?!
In case you are serious... yes... I just seem to always tear it apart for long periods of time
Old December 15th, 2008, 10:01 PM   #16
I think every time I've wheeled with someone with an OX, they've had it be finicky or not working at some point on the trip. Shame, seems like a good idea, but poor execution.
Old December 15th, 2008, 10:31 PM   #17
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
The issue with the OX in my mind is the travel from disengaged to engaged is very short in the diff...it's like 5/8 of an inch at the most. Then you have 6-8 feet of cable and then again 5/8 of an inch of movement at the levers.
There is so little room for error it's ridiculous. Setting up an OX has tested my patience more than almost anything I have ever done. On the other hand ARB's are a pleasure to install.
JcrOffroad
Zoom Zoom!
Old December 16th, 2008, 09:50 AM   #18
junk90xj
ALLPRO AUTO
junk90xj's Avatar
4.) They suck.
thats how i feel too.
i have a strong dislike of ox lockers
Old December 16th, 2008, 09:57 AM   #19
Bones
Bones's Avatar
Originally Posted by Monkeyevil View Post
The issue with the OX in my mind is the travel from disengaged to engaged is very short in the diff...it's like 5/8 of an inch at the most. Then you have 6-8 feet of cable and then again 5/8 of an inch of movement at the levers..
That is no different than every automatic transmission ever made. Aparently OX decided to skimp out on the quality of cable though.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old December 16th, 2008, 10:15 AM   #20
brimy311
brimy311's Avatar
Have you ever seen/played with an OX cable? They are not crappy by any means. The problem is with the adjustability. In order to adjust the OX locker cable, you have to remove the diff cover, adjust, put back together. Then you have to also get the shifter in unison with that. It is really easy to get it working outside of the vehicle, but once you route the cable into the cab, it becomes a nightmare. The cable is threaded on both ends and you have twist the cabe to screw it into the shifter. Once you have done, you have to twist the diff cover around to get the right setting both ends.
A B&M shift has a simular cable, but easier to adjust, as you can see the throw fork on the side of the transmision. You can not see the OX fork and it is a touchy biatch.
If I was given a free OX locker for my truck, I would throw it in the trash.
JcrOffroad.com
Like us on Faceook!
Page generated in 0.31639 seconds with 84 queries
